ProjeQtOr free project management software - Link Element Missing - Page 2 - ProjeQtOr
07 Jun 2021 15:24 #7 by fsouliers
Replied by fsouliers on topic Link Element Missing
no I hadn’t ... but actually the customization screen is getting mad and out of control ...
(the hidden checkbox of «liste des points à traiter» is actually unchecked and the position of «Traitement» moved when I tried to check/uncheck the «liste des points à traiter» ... and it doesn’t want to go back to its position)
12 Jun 2021 17:52 #8 by babynus
Replied by babynus on topic Link Element Missing
It seems you move «liste des points à traiter» (a section) after "description" (section)
Then the tool considered all items that were below "desction" section are new below "liste des points à traiter" section.
I guess you then moved section "liste des points à traiter" after "result"
I got same result as yours this way.
Only way to get things back is to move fields, one by one back under section description
Notice that moving a section may have weids behavior : if you move it before some fields, these fields will move into this section
Exemple : if you have
SECTION A
    fld1
    fld2
    fld3
    fld4
SECTION B
    fld5
if you move SECTION B after field fld2, you'll get
SECTION A
    fld1
    fld2
SECTION B
    fld5
    fld3
    fld4
The following user(s) said Thank You: fsouliers
