ProjeQtOr free project management software - Link Element Missing - ProjeQtOr
15 Apr 2021 17:48 #1 by karl.binet
HelloV 9.1.2
I'm am in an activity, it says 6 Linked element but there not showing  up
Any hint on how to solve the issue ?
15 Apr 2021 18:32 - 15 Apr 2021 18:35 #2 by babynus
Replied by babynus on topic Link Element Missing
It seems you have unconsistent custom file.
It may happen with customized object with older versions of Screen Customization
Open file projeqtor/model/custom/Activity.php and ensure that fields declaration sets $_sec_Link as almost the last position, just before $_nbColMax (not taking into accouns static fields)
You can refer to projeqtor/model/ActivityMain.php list of fields, that may be the same except for your own customizations.
  public $_sec_ToDoList;
  public $_SubTask;
  public $_sec_Link;
  public $_nbColMax=3;
  public static $_customFields=array(
Last edit: 15 Apr 2021 18:35 by babynus.
16 Apr 2021 23:47 #3 by Baryhobal
Replied by Baryhobal on topic Link Element Missing
We seem to have the same problem. We only noticed this recently, after updating to V9.1.2. It happened on a ticket. I've checked model/custom/Ticket.php but it seems correct. I also checked the database for any inconsistency in the link refs but there's no problem with that either.
26 Apr 2021 21:03 #4 by karl.binet
Replied by karl.binet on topic Link Element Missing
Thanks i have modified the file projeqtor/model/custom/Activity.php and everything went back to normal.
03 Jun 2021 16:40 #5 by fsouliers
Replied by fsouliers on topic Link Element Missing
I had the same problem with activities --> I applied the modification, it works now
I have the same problem with actions --> the model/custom/Action.php looks like the Activity one ... but the problem still exists :(
The very (very very) strange behavior is the following :
- it seems to work (on actions)
- then I set the status of the action to "closed" ... and the display bug is back!
04 Jun 2021 14:42 #6 by babynus
Don't you have some customization that hides things depending on status ?
