ProjeQtOr free project management software - [SOLVED] No messages - ProjeQtOr
28 Jan 2020 21:31 #1 by mcanuto
No messages was created by mcanuto
I've created a message to be shown on login screen a long time ago and many version ago.
Somewhen in time I was able to change it, but now, in version 8.2.4, I can't see any of the messages I've created and so, I'm not able to close them or even change them.
How can I recover those messages, is there a specific configuration to do this?
Thank you for your help.
MCanuto
29 Jan 2020 10:34 #2 by Gautier
Replied by Gautier on topic No messages
Could you post a screen of your message please.
31 Jan 2020 14:28 #3 by babynus
Replied by babynus on topic No messages
Check configuration of access rights to message.
If you defined a project for the message (that is not applied for Login screen display) and have restricted visibility, you may loose access.
31 Jan 2020 15:53 #4 by mcanuto
Replied by mcanuto on topic No messages
I've created the messages on the menu "Messages" as ADM (Adminitrator) who has a Manager+ right over Messages.
I didn't choose any profil, project or user and I've selected the option "show on login screen". The type of the last message is "INFORMATION", the other ones I don't remember
The message is shown in the login screen but not in Messages menu (even with the closed option selected).
In the database, I find all my messages. Do you see something that prevents me to see them under ProjeQtOr?
MCanuto
04 Feb 2020 12:21 #5 by babynus
1) try and reset display for columns
If usue persits :
2) check for errors in projector log file
3) check for errors in browser console.
05 Feb 2020 08:17 #6 by mcanuto
Replied by mcanuto on topic No messages - SOLVED
Babynus,
the problem is related to the browser. with Chrome I have several issues on display ( including the alignement of the headers on version 8.3.2).
Using Firefox, I can see my messages, now.
Can you tell me which browser is the most compatible, please?
Thanks a lot.
