ProjeQtOr free project management software - [SOLVED] No messages - Page 2 - ProjeQtOr
05 Feb 2020 09:12 #7 by babynus
Replied by babynus on topic No messages - SOLVED
Projeqtor is compatible with most common browsers (IE11, Chrome, Firefox, Edge, Opera, Safari, ...)
These is no "most compatible" browser.
IE11 may be the "less compatible" but we maintain compatibility with it.
For your header issue, I guess it is some cahcing issue : just clear your browser cache.
The following user(s) said Thank You: mcanuto
05 Feb 2020 13:55 #8 by mcanuto
Replied by mcanuto on topic No messages - SOLVED
Super Tip... Thanks!
15 Mar 2020 12:05 #9 by mcanuto
I write you again on this issue, because I can't see my messages no matter which browser I use.
I have no error on ProjeQtOr log and in the Browser Console, I don't really what to look for, but I saw this under Chrome (version : 80.0.3987.132 (Build officiel) (64 bits)) :
dojo.js?version=V8.3.6.0254:2 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
req.getText @ dojo.js?version=V8.3.6.0254:2
_33 @ dojo.js?version=V8.3.6.0254:2
_b @ dojo.js?version=V8.3.6.0254:2
(anonymous) @ dojo.js?version=V8.3.6.0254:2
_38 @ dojo.js?version=V8.3.6.0254:2
_7c @ dojo.js?version=V8.3.6.0254:2
_17 @ dojo.js?version=V8.3.6.0254:2
_8c @ dojo.js?version=V8.3.6.0254:2
load @ dojo.js?version=V8.3.6.0254:2
_ed @ dojo.js?version=V8.3.6.0254:2
_80 @ dojo.js?version=V8.3.6.0254:2
_f6 @ dojo.js?version=V8.3.6.0254:2
req @ dojo.js?version=V8.3.6.0254:2
Show 25 more frames
And under Firefox (version : 73.0.1 64 bits), I found this :
Cette page utilise la propriété non standard « zoom ». Envisagez d’utiliser calc() dans les valeurs des propriétés pertinentes ou utilisez « transform » avec « transform-origin: 0 0 ».
and
L’utilisation d’XMLHttpRequest de façon synchrone sur le fil d’exécution principal est obsolète à cause de son impact négatif sur la navigation de l’utilisateur final. Consulter http://xhr.spec.whatwg.org/ pour plus d’informations.
And on IE11 (version 11.719.18362.0) :
HTML1423: Format incorrect de la balise de début. Les attributs doivent être séparés par des espaces.
Does this provides you more information to help me solving my problem? Is it the XMLHttpRequest that is no longer compatible with browser's newer versions?
MCanuto
19 Mar 2020 19:14 #10 by babynus
No, there is no message that could help solve your issue.
Did you clear browser cache ?
Can you reset columns layout (use following button)
19 Mar 2020 23:12 #11 by mcanuto
Yes, I did both, but nothing changed.
Under Chrome and Firefox.
22 Mar 2020 20:29 #12 by babynus
Please check Project Selector.
If project is selected, only messages for this project are displayed.
