ProjeQtOr free project management software - LDAP Connection Problems - ProjeQtOr
23 Jan 2015 16:38 #1 by Romain
Hi all,
I try to use LDAP connection.
When I tried to connect :
Paramètres de connexion incorrects
And in the log file:
2015-01-23 16:35:17 ***** ERROR ***** Ldap not installed on your PHP server. Check php_ldap extension or you should not set $paramLdap_allow_login to "true"
I don't now where is the parameter "$paramLdap_allow_login" ?
My LDAP configuration:
connexion via LDAP : Yes
base dn LDAP : OU=FRA,DC=blemea,DC=bausch,DC=com
serveur LDAP : "name of my Active directory server"
port LDAP : 389
version LDAP : 3
utilisateur LDAP : cn=UserLDAP,dc=blemea,dc=com
mot de passe LDAP : *********
filtre pour utilisateur : sAMaccountName=%USERNAME%
My Active directory is Windows 2003 server.
ProjeQtOr V4.5.4
Thnaks for for help
Have a nice WE.
Romain
23 Jan 2015 19:41 #2 by babynus
Replied by babynus on topic LDAP Connection Problems
Issue is on your PHP installation.
LDAP extension is not enabled.
Check for php.ini file.
Possibly you just have to uncomment extension and restart php.
26 Jan 2015 11:32 #3 by Romain
Replied by Romain on topic LDAP Connection Problems
In my php.ini file I got only this parameter:
[ldap]
; Sets the maximum number of open links or -1 for unlimited.
ldap.max_links = -1
26 Jan 2015 12:00 #4 by Romain
I was run :
a2enmod ldap
service apache2 restart
And I haven't the error in the log :
26 Jan 2015 12:19 - 26 Jan 2015 13:09 #5 by babynus
The "a2enmod ldap" enables LDAP for Apache (for digest athentication or similar)
What you need is php_ladp extension.
Check you php.ini file.
You should have on windows
extension=php_ldap.dll
or on linux
extension=php_ldap.so
For instance, to install it on linux you need :
apt_get install php_ldap
for Debian like
or
yum install php_ldap
for RedHat like
Last edit: 26 Jan 2015 13:09 by babynus.
26 Jan 2015 17:33 #6 by Romain
In /etc/php5/mods-available/ldap.ini
Do you know where I can find logs ?
