ProjeQtOr free project management software - LDAP Connection Problems - Page 2 - ProjeQtOr
27 Jan 2015 11:43 #7 by babynus
Replied by babynus on topic LDAP Connection Problems
apache and php logs location depends on your OS and if linux on distribution.
On debian like it should be on /var/logs/apache2 if my remenbering is correct.
27 Jan 2015 14:00 #8 by Romain
Replied by Romain on topic LDAP Connection Problems
Yes, is /var/logs/apache2. But there aren't information for the LDAP.
It's work if I put base dn LDAP "DC=blemea,DC=bausch,DC=com". But I don't want to all people of my compagny create a account in ProjeQtor.
I would like only in this base "OU=Users,OU=TLS,OU=FRA,DC=blemea,DC=bausch,DC=com" can be connecting.
Thanks lot
28 Jan 2015 11:07 #9 by Romain
Dear all,
I have 2 questions on LDAP ?
1 / How I can setup the LDAP to check only the user in this Noeud : OU=Users,OU=TLS,OU=FRA,DC=blemea,DC=bausch,DC=com
2 / How I change a User created manually to become a LDAP user ?
29 Jan 2015 16:39 #10 by babynus
This should work.
You have to check that ldap user (defined in global parameters) correctly connects to this base DN. (check PHP ldap_bind documentation for help)
Other hint : uncomment the debugLog calls in User->authenticate(). This can give hint to unsuccessfull binding.
Maybe you can try to play with user filter criteria check PHP ldap_search documentation for help).
Concider that this search is done like in any other tool. For instance, you can try this filter in LdapBroser to see if it returns what you expect.
29 Jan 2015 16:40 #11 by babynus
You must update directly in database : set isLadap to 1.
30 Jan 2015 08:27 #12 by Romain
2/ Done
1/ I used LdapBroser to check the DN base and it is Ok. I'll try next week.
