ProjeQtOr free project management software - Using Ldap - ProjeQtOr
Using Ldap
18 Nov 2011 14:16 #1 by jul35
Using Ldap was created by jul35
if you want to use Ldap connector, you have to change $paramldap_allow_login by $paramLdap_allow_login in file parameters.php.
If you use easyPhp, you have to suppr ";" before extension=php_ldap.dll in php.ini
Jul'
18 Nov 2011 15:45 #2 by babynus
Replied by babynus on topic RE : Using Ldap
You're right Jul !
First step is an issue, appearing while migrating to V1.8 from previous version.
Installing from scratch will not reproduce.
=> Fixed. Fixing will be included in V1.9. Migrating to V1.8 will always generate the issue, to be fixed manually.
Second step is a good hint for EasyPHP users
=> I move this topic to "tips & tricks" !
