ProjeQtOr free project management software - Solution to enter a ballpoint position in Project expense - ProjeQtOr
06 Mar 2014 13:04 #1 by climb4fun
Hi all,
The issue you might have:
  • On project start we often know expense positions by naming them, but not the ballpoint / estimated amount. Hence we have to enter no value or even '0' in the amount field.
  • ProjeQtOr is checking this entry and rejecting value '0' in the amount field
  • :oops:
My proposed solution:
Enter '0,001' in the amount field. As this field will be rounded up, you have value '0' in your field. :)
I hope you like this workaround.
Klaus
