ProjeQtOr free project management software - [SOLVED] ATTENTION : ProjeQtOr is not compatible with MySql V8.0.20 - Page 2 - ProjeQtOr
28 Jul 2020 16:24 #7 by babynus
installation of projeqtor on a new machine
New machine means new software.
ProjeQtOr is not compatible with MySql V8.0.20.
Use an older version (V8.0.18 or older) or MariaDB or PostgreSql
28 Jul 2020 16:37 #8 by jeanmoulin
absolutely : As I said in my second post : " I will erase everything and install again with a different version of mysql, hopefully today or tomorrow." One of my technicians will do it tomorrow, then I will see if this solve the problem or not.
Otherwise I will write another post on the forum asking for help.
I just wanted to know if the database version could be an explanation to this problem or if i should look at other probable causes
29 Jul 2020 10:16 #9 by jeanmoulin
My technician just completed the install with a compatible version of mysql : I tried and it works fine, the drop-down menus are displayed. So the database version was the cause of this probleme.
thanks
