ProjeQtOr free project management software - My I define default Company Products? - ProjeQtOr
07 May 2019 21:53 #1 by zenoni
I would like to create all Products Models that my Company works and when a project need some of this product I just point to the products I'll currently use.
I made a test but when two projects point to the same product if one Project change some on this product affect the other project product.
So, if I understood, I will need to define the same product always that I want associated it to a project. Is that correctly?
11 May 2019 17:00 #2 by babynus
If two projects deal with same product, it is the same product. So it is normal that change done by one project affects the other project : it is the same product, not a copy of same kind of product..
Product management is not a catalog of items that can be used. We are not dealing with stock management.
