ProjeQtOr free project management software - Payment terms not visible anymore following upgrade to 7.4.4 - ProjeQtOr
19 Apr 2019 14:42 #1 by milien56
I use projeqtor with an administrator account.
Following the upgrade from 7.2.7 to 7.4.4, the "payment terms" list is now empty. I can create a payment terms, i can see from customer invoice and add it as invoice detail ...
However terms doesnot appear anymore in the list (there is no filter activated, terms are note closed ....etc).
Was working perfectly with 7.2.7
Is it a known issue ?
Thanks for your help
19 Apr 2019 15:13 #2 by babynus
Please refresh the list format : in column selector, clich on button reset, to reset to default configuration.
Then you can redefine your own.
The following user(s) said Thank You: milien56
19 Apr 2019 15:16 #3 by milien56
Thanks ! This solved my issue.
