ProjeQtOr free project management software - Activities Taking Less Than a Day - ProjeQtOr
25 Mar 2019 16:01 #1 by gohrner
That's possibly a stupid question, but I could not really find an answer so far in the online manual. Points to the correct docs are appreciated.
How can I deal with Acitivities which will only take about a few hours at most?
Are Activities supposed to be larger chunks of work? If so, how do I model small "Activities" in ProjeQtor?
I currently modelled several Activities which will only take about an hour or slightly longer, far from a whole day. However I don't seem to be able switch the "duration" input boxes to "hours", they always state "days". I was only able to switch the work allocation boxes from days to hours, but this didn't have any effect on the estimated duration entry boxes.
In this forum I read about the possibility to work with half-day activities at least, but I also cannot figure out how to do this. The input box does not accept "0.5" and while I can enter "0,5", this will be interpreted as "0" by ProjeQtor, which is clearly not what I intended it to be...
Another question which doesn't get clear from the manual: If a lower Activity priority value "more important" or a higher one?
Everywhere it's stated that Activity planning is done according to priority values, but I couldn't find a single place which actually explains how the priorities are supposed to be used. :) And while I already played with ProjeQtor for quite a while now, my modelled Projects / Activities are not yet sufficiently fleshed out such that I could just try it with the integrated planner. This will probably still take a while until I get to the point that I can actually press this button...
25 Mar 2019 16:28 - 25 Mar 2019 16:32 #2 by alainforma
All you need to do is go to the global parameters and then to the work section, then into work unit to change from day to hour.
Priorities are taken into account only after dependencies and some planning modes while respecting the availability and the working capacity of the resources.
That's why the button calculate the planning is done in order to present to you a capacity planning.
you can also use checklist or jobs list if you do not want to plan your activities because they are very short. LIke this, you have just to ckeck that is done or not.
we are carrying out some tutorials that will explain ( as soon as poosible) the right approach to adopt with the application.
Last edit: 25 Mar 2019 16:32 by alainforma.
25 Mar 2019 21:44 - 25 Mar 2019 21:45 #3 by gohrner
Thanks for your reply.
Unfortunately, I'm not quite sure if we understood each other correctly.
Please refer to the attached screenshots:
As I wrote, I was able to switch the work allocation boxes to hours with the config settings you see in the first screenshot.
However, the planning effort boxes do not respect this setting and still show "days" as the unit, as shown in the second screenshot.
How can I make those boxes respect the "hours" setting, as you suggest?
What is the "checklist" or "jobs list" you're suggesting to use? I've not read about those concepts so far in conjunction with ProjeQtOr. (pq.ohrner-it.com/docs/user/html_en/Concept.html)
Also, I still didn't understand whether a higher priority value means "more important" or a lower one - however I guess this distinction will be very important for correct planning.
So which value means "more important", a lower value ("Priority 1") or a higher value ("Priority 999")?
Thanks and regards,
Gunter
Last edit: 25 Mar 2019 21:45 by gohrner.
26 Mar 2019 18:30 - 26 Mar 2019 18:41 #4 by alainforma
Hi Gunter,
Trying to understand and solve your issue, i answer you firstly for your last question.
Prirority 1 is higher than 999. It means that the activity "1" is taken into account before that of "999" during the calculation. It does not mean that in fact "1" will be systematically planified before the "999" one. It is just an order that Projeqtor will try to respect depending on anothers priorities like and for instance "dependencies" beetween activities or some calculation modes.
Last edit: 26 Mar 2019 18:41 by alainforma.
26 Mar 2019 19:48 #5 by gohrner
Thanks a lot for your answer! :)
27 Mar 2019 09:37 - 27 Mar 2019 09:45 #6 by babynus
You can : just enter assigned work as hours... Planning will take it into account.
Don't mind about duration : projector always calculate durtion in days... so smallest duration is 1 day, even if it really takes 1 hour.
Yes. It is plroject management, not exploitation management.
Good scale for tasks, in my opinion is 5-10 days.
Larger tasks are difficult to understand by resource who will execute it.
Smaller will take too much time to manager of the project manager : he will spend more time to manage the tasks than the resource ot work on it...
You can enter assigned work of 1 hour, but duration will be displayed as 1 day. Duration is alwyas in open days and you cannot define duration with decimals.
Yes, smaller value is the more important. 1 is the highest priority.
Last edit: 27 Mar 2019 09:45 by babynus.
