ProjeQtOr free project management software - Issue on Gant pdf - ProjeQtOr
Issue on Gant pdf
22 Mar 2019 10:50 #1 by jszczygiel
Issue on Gant pdf was created by jszczygiel
When I generate a Gant into pdf ('pdf' button in Gant View), the result is not correct: headers not visible, and they are different polices sizes in the different pages. Please see the file.
The Projeqtor system is hosted: mypmo.projeqtor.org.
The tests have been made on MacOs / Safari, MacOs / Chrome, and by someone else on Windows 10, with the same result.
I have also tried to change the zoom level: it gives the same result.
But when, in the Gantt view, I use the print button, and then print into pdf, the result is correct, but in the bottom line, there's a Projeqtor technical link I don't want to appear and send to my contacts and ressources.
Please, can you help me?
Thank you in advance,
Joseph
22 Mar 2019 12:08 #2 by babynus
Replied by babynus on topic Issue on Gant pdf
We have recorded this issue.
At first analysis, it appears to happen when screen applies a zooming factor.
For instance on a laptop with full HD resolution but 13" display, you may use 125% or 150% zooming factor.
If you set to 100% you'll see pdf export is correct.
We are working on this issue to try and find a solution.
The following user(s) said Thank You: jszczygiel
