ProjeQtOr free project management software - how to migrate products, projects etc including databases from one system to oth - ProjeQtOr
16 Mar 2019 01:22 #1 by vasant63
I would like to know how one can migrate / duplicate the products, projects and other relevant items from one system to other systems.
22 Mar 2019 12:21 #2 by babynus
Only "clean" possibility is
- export (csv) list of items
- import the csv files with Import feature
Some dependant items won't be integrated : notes, attaches files, links, dependencies, ...
23 Mar 2019 16:04 #3 by vasant63
I have one idea, whether it is right or not?
Suppose one copies the subdirectory projeqtor in the MySQL/data to the other system. Will it work or not?
I am finding it difficult to export the csv files and import in the other system. Moreover the links are not copied.
Kindly provide your advise on the above idea.
Thanks in advance.
23 Mar 2019 17:14 #4 by babynus
Ni, copy data files is a bad idea.
If you want to copy all the data, you can easily expot db and import it on new system.
You can do this easily with phpMyAdmin or mySqlDumper or with line command mysqldump.
24 Mar 2019 14:19 #5 by vasant63
Thanks for your advise. I shall try the mysqldump and try.
27 Mar 2019 18:32 #6 by vasant63
vasant63 wrote: Thanks for your advise. I shall try the mysqldump and try.
I could successfully copy the MySQL database of projeqtor from one server to another server using the phpMyAdmin tools. Thanks for the help provided.
