ProjeQtOr free project management software - WBS issue when doing automatic import - ProjeQtOr
15 Mar 2019 11:15 #1 by tms
I have an issue with the WBS order when I am doing automatic import of files. I need to import projects, sub-projects, activities and milestones respectively. I created a batch file to do that . I managed to import them(a timeout had to be put between the activities and the milestones). But every time I do that import, i encounter an issue with the wbs order.
I always have to connect as admin, go to administration and click on "fix issues" several times to fix it. I don't know how to get rid off that issue. I am working with my test instance of Projector. I am scared when people will begin to do imputations.
I thank you in advance for your return.
Best regards
15 Mar 2019 17:34 #2 by babynus
What exactly did you do ?
20 Mar 2019 15:35 #3 by tms
I finally fix the issue. It 's working fine.
Best regards
