ProjeQtOr free project management software - Error planning calculation : unplanned work - Page 2 - ProjeQtOr
05 Jun 2019 15:39 #7 by babynus
How can I tell the planner that even if this project should occupy only 10% of the time of this resource, sometimes these meetings are prioritary over the other projects ?
You cannot bypass this constraint.
05 Jun 2019 16:03 #8 by aleleve
Ok. I understand that I cannot bypass it.
Therefore, is there a way to know how to unblock this situation (I just know that these meetings are problematic) or to organize more efficiently my projects so that this kind of situation works ?
Typically, I organized in various projects my activities which correspond to different charges.
I created some project templates containing milestones, activities and meetings (by the way, I have to set a fake date to the meetings) which enable to plan efficiently new projects.
I have ~10 parallel projects in parallel with ~ 10% assigned to me each.
I imagine that a full day meeting in a project where I am assigned 10% worries the planner ?
06 Jun 2019 17:58 #9 by babynus
No, you can manage it easily.
Just don't set restriction to allocation rate to project (set all at 100%).
Just set assignment rate to ensure you work at correct rate (10%) on each in parallel.
This way, meetings whould be correctly planned.
07 Jun 2019 08:26 #10 by aleleve
Thanks for your quick answer.
Just to be sure I set the right parameters at the right place:
- in the resource page, I set every project rate at 100% even if it worries Projeqtor that the total amount of affectations is over 100%
- in the assignation of each task I put the real rate, say 10%
07 Jun 2019 15:43 #11 by babynus
Yes
The following user(s) said Thank You: aleleve
