ProjeQtOr free project management software - [SOLVED] Max Projects to display exceeded - ProjeQtOr
07 Mar 2019 09:01 #1 by clarezoe
I'm very new to ProjeQtOr but I hope our team could use this for our projects. I have added 59 projects (including sub projects) and when I open Planning I got the error "Max Projects to display exceeded". I have searched the forum and the manual but didn't find any information. I tried the filter to narrow down the amount of project but the Alert pops up even when only one project selected. Please advice! Thanks!
=> version of ProjeQtOr: 7.4.2
=> browser used (en version): Chrome 72.0.3636.119 (Official Build)
No error message in the log file.
Thanks in advance!
07 Mar 2019 09:13 #2 by babynus
You have to select a project in the project selector (to limit view).
This is to avoid performance issue with the browser when displaying gantt chart.
You can also increase global parameter "max projects to display"
07 Mar 2019 09:38 #3 by clarezoe
Thank you very much for the prompt response!
I figured out the place to choose the project and now I have changed the global parameters. Everything looks fine. :side:
