ProjeQtOr free project management software - [SOLVED] Enter work as planned disappear - ProjeQtOr
25 Feb 2019 10:17 #1 by mcanuto
I've calculated my planning but sometimes the button "Enter work as planned" is not visible dispite the option "show planned work" activated.
Can you tell me what other conditions do I have to consider so this button is visible?
Thank you
MCanuto
25 Feb 2019 14:11 #2 by babynus
To avoid display issue, this button is hiiden for "low resolution" screen.
So if place for timesheet screen is lower thant 1150px, button is hidden.
The following user(s) said Thank You: mcanuto
