ProjeQtOr free project management software - Planning Management - ProjeQtOr
Planning Management
23 Feb 2019 10:45 #1 by JB21
Planning Management was created by JB21
I want to be able to define an action just 10 days before a milestone. If the load is too large it would have to be 11 days, pulse 12 etc. But I don't wish it to be placed as soon as possible.
I didn't found a little elegant solution : A negative ejours number by defining the action after the milestone.
Example: convening a meeting which must be carried out 10 days before.
Thank you for your help
24 Feb 2019 19:01 #2 by babynus
Replied by babynus on topic Planning Management
Keep planning mode as "asap", but define a dependency "end-end" from milestone to activity.
25 Feb 2019 15:39 #3 by JB21
Replied by JB21 on topic Planning Management
Thanks for your reply,
I did not understand... As can be seen on the attached catch, the activity is programed as soon as possible.
Thanks in advance for your answer,
25 Feb 2019 15:42 #4 by babynus
Take care of the way you define the dependency.
For end-to-end dependency, the predecessor (the one you drag from) is calculated, then the successor (the one you drag to) is calculated backward
