ProjeQtOr free project management software - Timesheet Display Order - ProjeQtOr
19 Feb 2019 16:44 #1 by karl.binet
What is the default sorting order in TimeSheet ? Project/Activities are not in order lowest/highest.
Is it possible to sort item in timesheet by Project ID
19 Feb 2019 17:02 #2 by babynus
Replied by babynus on topic Timesheet Display Order
Items are sorted by WBS (like on Gantt Chart)
19 Feb 2019 17:27 #3 by karl.binet
Replied by karl.binet on topic Timesheet Display Order
Can we change the sorting order ?
19 Feb 2019 17:51 #4 by babynus
You can reorder projects in Planning view (Gantt Chart) or Project Portfolio view.
(drag and drop projects)
03 Sep 2024 15:47 #5 by Irma
Replied by Irma on topic Timesheet Display Order
Hello! I'm having some issues with the display of activities and projects on the timesheet. I have the default project #1 - PROJECT - LEAVE PERIOD, to which the "Ferie" (Holidays) and "Permessi" (Leave) types should be associated. However, these activities appear to be associated with another project, and I'm unable to move them correctly. I am attaching a screenshot. Thank you very much for your response.
04 Sep 2024 10:19 #6 by Arkhanje
Replied by Arkhanje on topic Timesheet Display Order
The projects and activities of the HR module are hidden in the lists.
To add leave in the HR module, you must go to absence types and create your leave from this screen.
The activities will be automatically added to the Leave project of the HR module.
Similarly, these leaves will not be available - read only - in the timesheet, you will have to record the leave in the HR module either on the Absence Calendar screen or on the absence period.
Therefore, it will be impossible for you to move your already existing activities.
The following user(s) said Thank You: Irma
