ProjeQtOr free project management software - Publish general communications for a project - ProjeQtOr
12 Feb 2019 20:16 #1 by Yannobi
I'm looking for a way for the project manager to publish informations for a specific project on Projeqtor. Informations exposes actuality of the project. And i want these communications to be visible for all team members affected to te project
Do you have an idea to do this with Projeqtor ? "Notes" are not enough cause communications are bigger than simple notes, and i'd like to found all this communication on a single place, sorted by date.
Thank all for your ideas.
Yann
13 Feb 2019 10:35 #2 by Damian.sd
you can already use activity stream on project to send actuality at all project team member.
First go to project, open activity stream on right and send your project actuality.
Then you go on activity stream screen for a global view of your project actuality.
Damian.
13 Feb 2019 12:23 #3 by Yannobi
Ok, i 'll try that way !
