ProjeQtOr free project management software - [SOLVED] API POST Issues - Page 2 - ProjeQtOr
08 Feb 2019 15:45 #7 by babynus
Replied by babynus on topic API POST Issues
Look at exemples.
Data miust be passed in json format, encrypted with API key
08 Feb 2019 15:51 #8 by CarlC
Replied by CarlC on topic API POST Issues
I read the examples and old user manual but those are all for using the API with PHP code which i don't know so i need to do it another way.
I can successfully use cURL and Invoke-WebRequest (powershell) to GET and POST to other API's but i don't understand why the same methods won't work with Projeqtor.
You mention the data has to be encrypted with the API key but i can't find any documentation or examples which show how to do this - except your PHP example.
If there are other examples i have missed please let me know and i'll have a read through them.
08 Feb 2019 16:08 #9 by CarlC
Figured this out and now have a workable command-line version of cURL which is successfully doing both GET and POST.
I think the problem was a combination of:
1) the wrong key length (i've changed it to 256 instead of 128)
2) JSON data wasn't encrypted quite right (don't know how but i pulled it apart, re-encrypted it and now it works)
3) Wrong credentials used for writing (even though the same username/password worked fine for reading)
28 Feb 2025 16:16 #10 by CAIE_guens
Replied by CAIE_guens on topic API POST Issues
HI
with a length of 128, I have the same error message.
If you'll have a full doc, i think I missed somthig.
thanks.
Guenole
