ProjeQtOr free project management software - Add many ressources to one project - ProjeQtOr
31 Jan 2019 17:41 #1 by Bena
I need to add many people with the guest probile to one project.
Is it possible to add all users at the same time or should I add them individually ?
Regards.
Bena
31 Jan 2019 20:08 #2 by babynus
There is not "quick" way, unless resources are in the same team (you call allocate all resources of teams through team screen)
Possibly you can "import" allocation.
The following user(s) said Thank You: Bena
