ProjeQtOr free project management software - Project selector - ProjeQtOr
Project selector
24 Jan 2019 14:55 #1 by lsigroup
Project selector was created by lsigroup
Th project selector display only the name of the project. But in my case, i have more than 60 current projects and i would like to distinguish them by customer for example. Is it possible to display an additional information such as customer as a prefix, or something else?
Damien
24 Jan 2019 16:52 #2 by alainforma
Replied by alainforma on topic Project selector
HI,
On the list of all projects you can use the icon "filter" to get a new list filtered by customer.
Dynamic option filter allow you to choose which customer(s) you select each time you will use this filter.
24 Jan 2019 17:28 #3 by lsigroup
Replied by lsigroup on topic Project selector
I understand what you explain, but you do not reply to my request. I'm talking about Project Selector at the top left of the screen
25 Jan 2019 14:17 #4 by babynus
Replied by babynus on topic Project selector
alainforma's answer is correct
On right side of project selector, you have a magnifyer to search for projects.
You get the project list (like on project screen) where you can search on customer.
30 Jan 2019 17:24 #5 by lsigroup
I will try to make both of you understand better:
Is it possible to get project selector look like the attach file?
To have a hierarchy by customer ?
31 Jan 2019 09:29 #6 by babynus
Well it already does, if you sdelect the "stadard format"
Now, the "Customer" level is not generated automatically.
(you need by customer, but other will need by product or by organization or by projectg type...)
You need to define yourself the coreesponding structure with a "fake" project to define the customer level (and set the projects of this customer as sub-project)
