ProjeQtOr free project management software - Context of a ticket : How does it works ? - ProjeQtOr
21 Jan 2019 14:24 #1 by dnaton
I want to know how works the fields "Context" in the ticket screen.
By default, Ther is 3 fields, corresponding to environment, OS and browser.
what I'm looking for :
* is it possible to modify the lists of each context ? If yes, where is it possible ?
* is it possible to modify the name of one of theses three contexts.
If I take a look in Parameters/Lis of types, I see type of context but I can't create a new (and can't modify thoses which exist) and I don't see where are the value for each context.
Thanks for your help :-)
Damien
22 Jan 2019 16:00 #2 by babynus
Yes, in Environmental parameters / Context
Yes, Parameters / List of Types / Context types
23 Jan 2019 08:38 #3 by Envergus
Hi Babynus,
The problem is in these two lines in ContextType.php:
public $_noDelete=true;
public $_noCreate=true;
I don't know what is the purpose of these lines and if this persists in new versions.
23 Jan 2019 08:44 - 23 Jan 2019 08:47 #4 by dnaton
Is it possible to modify the name of one of theses three contexts ?.
In fact, not in my case : I don't have the capability to modify the name of the context : the field is grey :-(
Damien
Last edit: 23 Jan 2019 08:47 by dnaton.
23 Jan 2019 08:48 #5 by Envergus
Hi dnaton
you can comment the lines in ContextType.php:
till we get the feedback from Babynus
23 Jan 2019 14:29 #6 by dnaton
Damien
