ProjeQtOr free project management software - Visibility for selected projects - ProjeQtOr
19 Jan 2019 08:21 #1 by leader93
I search but doesn't found how we can give possibility to see only selected project for some users.
Is it possible ?
All users can see all project and see the project list. It is not possible for me to give visibility to the list for un external user for example. We must assume confidentiality.
Can you help me. Where can i find this information or, is it simply a configuration defect in my part.
Thank you in advance for your return.
20 Jan 2019 14:33 #2 by babynus
Of course it is possible.
It is basis or rights management for projeqtor.
By default, users with profil "Project leader" or "Team member" see only projects they are allocated to.
I guess your users have some profile Administrator or Supervisor : with this profile, they see all projects without having to be allocated to them.
With all other profiles (unless you changed default access rights) users must bez allocated to a project ot see its items. Otherwise, it is for them as if this project does not exist.
The following user(s) said Thank You: leader93
22 Jan 2019 14:42 #3 by leader93
OK many thanks. I modified profil (no admin or supervisor) and it is now OK
