ProjeQtOr free project management software - Fail at first login - ProjeQtOr
Fail at first login
10 Jan 2019 13:29 #1 by FredJ-INTRA
I installed ProjeQtOr for testing.
I tried to follow the installation instructions as defined in readme.txt (aka unzip the downloaded archive in my server folder) but when trying to log in I get the error message ~"incorrect credentials" ("Paramètres de connexion incorrects" in French).
V7.3.3 (last stable) on a local server with php-5.6.18 and mysql-5.7.11 (OS Win7pro).
On the configuration page I almost only changed the mysql passwd and the locale.
The log file finishes with these lines :
2019-01-10 13:04:26.519 ..... SCRIPT .... ::1    ->/tool/loginCheck.php
2019-01-10 13:04:26.529 ----- DEBUG ----- loginCheck : current db version = 'V0.0.0'
2019-01-10 13:04:26.539 ----- DEBUG ----- loginCheck : no user with name 'admin'
2019-01-10 13:04:26.544 ===== TRACE ===== Login error for user 'admin'
But in phpMyAdmin I can see the admin user in the resource table...
(see attached capture)
Looks like this post because the resource table has no 'crypto' field.
I have no idea how to deal with this, thak you for your help
Frédéric
16 Jan 2019 18:40 #2 by babynus
Replied by babynus on topic Fail at first login
Can you explicit instazll / config steps
Here is what you should have done :
- unziped files
- go to yourhost/projeqtor
- enter values in configuration field, then click OK
- see all config checks (all green ?), then click again on OK
- have login page, connect as admin / admin, wait a bit until migration message displayed (green message ?)
- Connect again as admin / admin...
If this is waht you did, please post content of projector log file and apache error log file.
17 Jan 2019 10:41 - 17 Jan 2019 10:42 #3 by FredJ-INTRA
Replied by FredJ-INTRA on topic Fail at first login
Thank you for your reply, I finally found my problem :
Analyzing the installation log I noticed it was interrupted during the installation, I think I didn't wait enough during this phase and clicked or refreshed the page before the installation finished.
during a fresh new attempt I left in peace my computer and the database creation finished well... in almost 20 minutes.
I strongly suggest to warn the users that this first creation can be really long (file readme.txt / paragraph Configuration / line "...database will be automatically updated").
Thank you babynus for your replay, and all the community for your work on this promisind project (I still need more effort to get the best of it, I can't assure for now that i will use it for real)
Fred
Last edit: 17 Jan 2019 10:42 by FredJ-INTRA.
17 Jan 2019 15:47 #4 by babynus
You must have very slow server.
I never saw first install longer than 2-3 minutes.
On my hosting servers it takes about 10-15 seconds...
