ProjeQtOr free project management software - Screen Customization - Sub-project Field - ProjeQtOr
19 Dec 2018 12:18 #1 by tms
As I told you before, I am using the screen customization plugin. I really appreciate it !! I created some projects' templates. I would like to use them as a sub-projects. When I click on the sub-project field, I want that only a particular type of projects (Not all) to appear. Is that possible ? I really need that for my work. I hope you understood my question. If I need to modify the code, could you give me the name/location of the source file? Thank you very much for your return.
Best regards
19 Dec 2018 21:06 #2 by babynus
I don't understand what you try to do.
Could you explain with screenshots ?
20 Dec 2018 10:49 #3 by tms
I will take a use case :
- I have 2 projects and 2 templates as below :
- I want to create a new project (project 3) by copying the template1 :
--> As I want to put this new project as a sub-project of another, I click on the list-field "is sub-project of":
--> As you can see above, When I do that, all the projects appear on the list (even the templates).
My question is :
Is it possible to hide in this list the templates (I don't want them to appear) ?
I have 3 other (simple) questions which are not related to the topic above :
1) Is it possible to not increment the WBS value for project's template ?
2) How can I initialize the first WBS value at 1 (my wbs values begin at 232 after I have deleted all projects in the database) ?
3) Is it possible to lock a type of project to a type of profile?
I thank you again for your availability.
Best regards
20 Dec 2018 16:37 #4 by babynus
You can see templates in copy because you manage them (you are admin or allocated to the project).
If you :
- set project type as "Template" to the template projects
- connect as project leader (that is not allocated to the project)
You will :
- see Template in the project list,
- not be able to change it,
- be able to copy it
- won't see it in copy form
No, they are projects, like any other project
Move one project.
It will force renumbering.
Yes, on profie, restriction of types...
The following user(s) said Thank You: tms
