ProjeQtOr free project management software - Database migration and utf8 char conversion - ProjeQtOr
08 Dec 2018 12:44 #1 by phvincent
Hello All
I've successfully migrated my projeqtor DEV environment from 6.2.4 to 7.2.7 (I was doubtful but finally it's a great job from you to maintain migration pathes :-) ).
Database is fine except that existing non-ascii chars are not well displayed.
Initial v6 DB had UTF8 charset and utf8_general_ci collation; same for new v7 database.
Did I miss something in the migration setup?
I'd like to solve this issue before migrating my PROD environment for 2 main reasons:
1) providing a correct data display to my users (obvious)
2) more important: make the projeqtor API return well-encoded chars! This is because I developed php scripts using API and json_decode()... which fails when API return json objects with incorrect chars
Thanks for your advices
08 Dec 2018 13:58 #2 by babynus
Please explain :
How you installed Dev env ( I guess charset issue appears here before migration )
Hiw you migrated
08 Dec 2018 15:00 #3 by phvincent
DEV was installed with standard method : unzipping v7 package in a new htdocs folder (xampp), leaving the v6 database online to start migration process at first admin login.
I've checked my database is correctly setup and populated after migration.
Continuing investigation I found a workaround: adding "$enforceUTF8='1';" in my parameters.php file (it was present in v6 but disappeared in v7).
Issue seems to be solved.
If you think there's a better way, please let me know.
Cheers
11 Dec 2018 09:17 #4 by babynus
Issue was to unzip in new folder : you should overwrite existing code with new one.
11 Dec 2018 09:57 #5 by phvincent
Hello Dear Babynus
Ok... I didn't pay attention to the fact that new release has no "default" parameters.php file, so I guess my old parameters would have been preserved.
Thanks for your support and have a nice day
