ProjeQtOr free project management software - Product Versions - ProjeQtOr
Product Versions
06 Dec 2018 23:56 #1 by andyb
Product Versions was created by andyb
If I try to save a product version, it fails with a big red error.
Looking in the error log then it seems to be this query which fails:
select count(*) as cpt from version where idProduct=1 and versionNumber='1.0' and id!=-1
I've highlighted the part which fails in bold
which is at line 458 in the file /model/Version.php:458
If I amend the code to put a space between the = and - then it work successfully
select count(*) as cpt from version where idProduct=1 and versionNumber='1.0' and id!= -1
07 Dec 2018 10:31 #2 by babynus
Replied by babynus on topic Product Versions
Thanks for posting issue and fix.
Fix will be included in next patch.
