ProjeQtOr free project management software - [SOLVED] Problem with direct link to activity in email and ${url} tag - ProjeQtOr
03 Dec 2018 16:03 #1 by niny1992
I've make the installation of projeQtOr on a Raspberry pi. I've actually a problem when i send user information. The url sended by mail is not correct. I have http://_ instead of http://"my ip address".
I have the same problem with the links in Activity emails.
I don't have any informations in the log file. Did i forget to install a package on my web server?
Thanks in advance
ProjeQtOr V7.2.7
04 Dec 2018 13:54 #2 by babynus
Could you please show content of variable $_SERVER on PHP
You can for instance create new file in web directory test.php containing :
<?php var_dump($_SERVER);?>
04 Dec 2018 17:11 #3 by niny1992
The result is : "_"
04 Dec 2018 19:25 #4 by babynus
Ok
In your conf, SERVER_NAME is not known.
We'll try and provide some patch.
As a workaround, add this line in parameters.php :
$_SERVER['SERVER_NAME']=$_SERVER['SERVER_ADDR'];
04 Dec 2018 20:28 #5 by niny1992
It works.
Thank you for help.
