ProjeQtOr free project management software - Projeqtor keeps Losing it's Connection - ProjeQtOr
25 Nov 2018 16:46 #1 by indieben
PHP 7.2 Environment
Debian 9 Apache Server.
Projeqtor Version 7.2.7
Hi, I keep having Projeqtor lose it's connection. Here is details from the web server log:
root@jacob2:/var/www/garethbaileygroup.com/log# tail -40 error.log
[Sun Nov 25 15:23:46.178838 2018] [fcgid:warn] [pid 20262] [client 192.168.1.254:40844] mod_fcgid: stderr: PHP Warning: session_start(): Failed to decode session object. Session has been destroyed in /var/www/clients/client1/web3/web/workflow/projeqtor/tool/projeqtor.php on line 39
[Sun Nov 25 15:23:46.178872 2018] [fcgid:warn] [pid 20262] [client 192.168.1.254:40844] mod_fcgid: stderr: PHP Fatal error: Uncaught Error: Call to undefined function htmlGetErrorMessage() in /var/www/clients/client1/web3/web/workflow/projeqtor/model/persistence/Sql.php:272
[Sun Nov 25 15:23:46.178880 2018] [fcgid:warn] [pid 20262] [client 192.168.1.254:40844] mod_fcgid: stderr: Stack trace:
[Sun Nov 25 15:23:46.178887 2018] [fcgid:warn] [pid 20262] [client 192.168.1.254:40844] mod_fcgid: stderr: #0 /var/www/clients/client1/web3/web/workflow/projeqtor/model/persistence/Sql.php(84): Sql::getConnection()
[Sun Nov 25 15:23:46.178893 2018] [fcgid:warn] [pid 20262] [client 192.168.1.254:40844] mod_fcgid: stderr: #1 /var/www/clients/client1/web3/web/workflow/projeqtor/model/persistence/SqlElement.php(2371): Sql::query('select * from p...')
[Sun Nov 25 15:23:46.178900 2018] [fcgid:warn] [pid 20262] [client 192.168.1.254:40844] mod_fcgid: stderr: #2 /var/www/clients/client1/web3/web/workflow/projeqtor/model/Parameter.php(982): SqlElement->getSqlElementsFromCriteria(NULL, false, ' (idUser is nul...')
[Sun Nov 25 15:23:46.178907 2018] [fcgid:warn] [pid 20262] [client 192.168.1.254:40844] mod_fcgid: stderr: #3 /var/www/clients/client1/web3/web/workflow/projeqtor/tool/projeqtor.php(2308): Parameter::getGlobalParameter('logLevel')
[Sun Nov 25 15:23:46.178914 2018] [fcgid:warn] [pid 20262] [client 192.168.1.254:40844] mod_fcgid: stderr: #4 /var/www/clients/client1/web3/web/workflow/projeqtor/tool/projeqtor.php(2422): logTracing('Impossible to l...', 1)
[Sun Nov 25 15:23:46.178920 2018] [fcgid:warn] [pid 20262] [client 192.168.1.254:40844] mod_fcgid: stderr: #5 /var/www/clients/client1/web3/web/workflow/projeqtor/tool/projeqtor.php(1435): errorLog('Impossible to l...')
[Sun Nov 25 15:23:46.178927 2018] [fcgid:warn] [pid 20262] [client 192.168.1.254:40844] mod_fcgid: stderr: #6 [internal function]: projeqtorAutoload('BreadCrumbStack')
[Sun Nov 25 15:23:46.178933 2018] [fcgid:warn] [pid 20262] [client 192.168.1.254:40844] mod_fcgid: stderr: #7 [internal function]: spl_autoload_call('BreadCru in /var/www/clients/client1/web3/web/workflow/projeqtor/model/persistence/Sql.php on line 272
Any help would be greatly appreciated. Any questions, please feel free, anything complicated, please would you give a step by step to either try a fix or provide useful information (that saves ping pong).
Thanks very much,
Kind Regards.
indieben.
25 Nov 2018 17:41 #2 by babynus
Session was killed.
Please check projeqtor log file.
The following user(s) said Thank You: indieben
25 Nov 2018 18:16 #3 by indieben
Thanks but this has even less info:
2018-11-25 15:24:01.613 ===== TRACE ===== Login error for user 'bgareth'
2018-11-25 15:24:05.770 ===== TRACE ===== NEW CONNECTED USER 'admin'
2018-11-25 15:26:08.287 ===== TRACE ===== NEW CONNECTED USER 'admin'
2018-11-25 15:29:27.661 ===== TRACE ===== NEW CONNECTED USER 'admin'
2018-11-25 15:30:14.908 ===== TRACE ===== NEW CONNECTED USER 'admin'
25 Nov 2018 18:37 #4 by babynus
Right, nothing from ProjeQtOr.
So you may be facing PHP or Apache session timeout.
Does diconnection occur after some time, after some inactivity time, or quickly after connection ?
25 Nov 2018 18:41 #5 by indieben
After some time i'd say. At first I thought it was after some inactivity (i.e. a few minutes) but I had to select a few things fairly quickly and it still kicked me off.
I'm not having any other issues like this across the domain though. Just in case, do you have a list of any necessary and preferable PHP mods that need to be installed? I'd be more than happy to double check all the necessary mods are installed for PHP 7.2. Thanks :)
25 Nov 2018 19:18 #6 by babynus
Required modules are listed on website : www.projeqtor.org/en/product-en/technica...uct-prerequisites-en
They are also controlled during setup.
