ProjeQtOr free project management software - How to gain entry for Admin after upgrade to 7.2.7? - ProjeQtOr
15 Nov 2018 10:32 - 15 Nov 2018 10:49 #1 by NarayanAras
Our ProjeQtOr was upgrdade from 7.1.5 to 7.2.7.
As usual, it shows a red message box stating
Upgrade in process.
Only Admin user can connect.
It requires the Admin (me) to log in first.
But ProjeQtOr does not accept my user name and password (something went wrong).
And if Admin cannot log in, the new version cannot start!
Question is, what is the way to gain entry?
We have another system user who has the top privilege (same as Admin).
But after the upgrade, he cannot login using his name and password.
Thus we are in a catch 22 situation.
How to break this impasse?
Last edit: 15 Nov 2018 10:49 by NarayanAras.
15 Nov 2018 11:21 #2 by Damian.sd
Its normal after an upgrade, you need to connect you with user administrator account.
15 Nov 2018 11:46 #3 by NarayanAras
Of course, but it is not working. Now what to do?
15 Nov 2018 23:57 #4 by babynus
This is very clear, exactly how I like to read bugs : it's not working...:evil:
Now what to do?
What you must do is ... clearly describe your issue : what you do, what you expect, what you get B)
16 Nov 2018 07:21 #5 by NarayanAras
Well, Damian.sd actually told me something that I already know and do as a routine, for each and every upgrade.
In that context I said that "it is not working".
Really, there is nothing else to report.
Let me rephrase the description:
After every upgrade, I see the same message "upgrade in progress/Only Admin user can connect".
As a routine, I do that and carry on with the latest version.
But not this time: It does not let me log in. It reports wrong login parameters.
So, my question was, if the admin cannot log in, what do I do next?
For the time being, we reverted to the old version.
16 Nov 2018 10:35 #6 by babynus
1) Try and clean browser cache, or try with another browser
2) Check for errors in projeqtor log file and post them here
3) Check for errors in browser console and post them here
