ProjeQtOr free project management software - Editing color scheme - possible? - ProjeQtOr
28 Oct 2018 15:15 #1 by Amema
I would like to use the ability to choose colors for different items much more extensively. But the default scheme does not reflect our needs.
Is it possible to edit the colors? If so, where?
Started using ProjeQtOr in oct 2018. Using it in a very small NGO to try to infuse some kind of oversight and order, and for private matters to learn more about it. Have "translated" parts into Swedish (and will make an Esperanto version as well), but not officially.
28 Oct 2018 15:30 #2 by babynus
No, unless you design a new theme (required some coding)
28 Oct 2018 15:32 #3 by Amema
If it's nothing worse than editing a file, rearranging RGB's or whatever, I can do that.
28 Oct 2018 15:40 #4 by babynus
Not only...
You must edit .css files with new theme name.
Then you have to add your theme on parameters.
28 Oct 2018 16:52 - 28 Oct 2018 16:55 #5 by Amema
Ouch. Disappointed. The current colors are not very many, but quite a few are very similar, while others are missing, which makes them not as useful as they could be.
And if I would meddle in the core code, I'm sure all would be lost in the next update...
Last edit: 28 Oct 2018 16:55 by Amema.
