ProjeQtOr free project management software - [SOLVED] Project description - ProjeQtOr
23 Oct 2018 17:14 #1 by ENVTIsm
Project description was created by ENVTIsm
I want to remove some descriptions in the Project (creation, lecture) : contract code, client...
Are these descriptions are optional?
That you for your help.
Ism
23 Oct 2018 17:26 #2 by Gautier
Replied by Gautier on topic Project description
Indeed these descriptions are optional and you can not remove or hide these fields.
But you can ignore them if you don't need it.
However there is a way to remove field, you can personalize your screen with our Screen Customization plugin, you should visit our shop plugin screen customization .
The following user(s) said Thank You: ENVTIsm
