ProjeQtOr free project management software - [SOLVED] Installation Issue on Ubuntu under Lighttpd - "Upgrade in currently running" - ProjeQtOr
25 Sep 2018 19:57 #1 by jmetcalf
Hello all,
I am attempting to install ProjecQtOr on a test server to evaluate it for my company. The server is Ubuntu 18.04.1 running lighttpd for the webserver with MySQL as the database.
After installation when attempting to login as admin/admin I receive the following message "Upgrade in currently running. Wait until it ends".
I have let the server running for over an hour and the message persists. I have also attempted to login with multiple different browsers (Chrome, Edge, and Firefox).
Can anyone suggest what might be the issue and recommend how to correct the issue?
Thank you,
Jon
below is the contents of the log file:
2018-09-25 12:06:59.105 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.resource' doesn't exist
2018-09-25 12:06:59.105 ***** ERROR ***** [] For query : select * from resource where resource.name='admin' and resource.isUser = '1'
2018-09-25 12:06:59.105 ***** ERROR ***** [] Strack trace :
2018-09-25 12:06:59.105 ***** ERROR ***** [] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2371]
2018-09-25 12:06:59.105 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2665]
2018-09-25 12:06:59.105 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/var/www/html/projeqtor/tool/getHash.php:48]
2018-09-25 12:09:01.306 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.resource' doesn't exist
2018-09-25 12:09:01.306 ***** ERROR ***** [] For query : select * from resource where resource.name='admin' and resource.isUser = '1'
2018-09-25 12:09:01.306 ***** ERROR ***** [] Strack trace :
2018-09-25 12:09:01.306 ***** ERROR ***** [] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2371]
2018-09-25 12:09:01.306 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2665]
2018-09-25 12:09:01.306 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/var/www/html/projeqtor/tool/getHash.php:48]
2018-09-25 12:09:02.316 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.resource' doesn't exist
2018-09-25 12:09:02.316 ***** ERROR ***** [] For query : select * from resource where resource.name='admin' and resource.isUser = '1'
2018-09-25 12:09:02.316 ***** ERROR ***** [] Strack trace :
2018-09-25 12:09:02.317 ***** ERROR ***** [] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2371]
2018-09-25 12:09:02.317 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2665]
2018-09-25 12:09:02.317 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/var/www/html/projeqtor/tool/getHash.php:48]
2018-09-25 12:09:10.242 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.resource' doesn't exist
2018-09-25 12:09:10.243 ***** ERROR ***** [] For query : select * from resource where resource.name='admin' and resource.isUser = '1'
2018-09-25 12:09:10.243 ***** ERROR ***** [] Strack trace :
2018-09-25 12:09:10.243 ***** ERROR ***** [] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2371]
2018-09-25 12:09:10.243 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2665]
2018-09-25 12:09:10.243 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/var/www/html/projeqtor/tool/getHash.php:48]
2018-09-25 12:30:56.322 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.resource' doesn't exist
2018-09-25 12:30:56.322 ***** ERROR ***** [] For query : select * from resource where resource.name='admin' and resource.isUser = '1'
2018-09-25 12:30:56.322 ***** ERROR ***** [] Strack trace :
2018-09-25 12:30:56.322 ***** ERROR ***** [] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2371]
2018-09-25 12:30:56.322 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2665]
2018-09-25 12:30:56.322 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/var/www/html/projeqtor/tool/getHash.php:48]
2018-09-25 12:36:34.716 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.resource' doesn't exist
2018-09-25 12:36:34.716 ***** ERROR ***** [] For query : select * from resource where resource.name='admin' and resource.isUser = '1'
2018-09-25 12:36:34.717 ***** ERROR ***** [] Strack trace :
2018-09-25 12:36:34.717 ***** ERROR ***** [] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2371]
2018-09-25 12:36:34.717 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2665]
2018-09-25 12:36:34.717 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/var/www/html/projeqtor/tool/getHash.php:48]
2018-09-25 12:45:57.609 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.resource' doesn't exist
2018-09-25 12:45:57.609 ***** ERROR ***** [] For query : select * from resource where resource.name='admin' and resource.isUser = '1'
2018-09-25 12:45:57.609 ***** ERROR ***** [] Strack trace :
2018-09-25 12:45:57.609 ***** ERROR ***** [] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2371]
2018-09-25 12:45:57.609 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2665]
2018-09-25 12:45:57.609 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/var/www/html/projeqtor/tool/getHash.php:48]
below is the output of info.php:
PHP Version 7.2.10-0ubuntu0.18.04.1
System Linux Databox 4.15.0-34-generic #37-Ubuntu SMP Mon Aug 27 15:21:48 UTC 2018 x86_64
Build Date Sep 13 2018 13:45:02
Server API CGI/FastCGI
Virtual Directory Support disabled
Configuration File (php.ini) Path /etc/php/7.2/cgi
Loaded Configuration File /etc/php/7.2/cgi/php.ini
Scan this dir for additional .ini files /etc/php/7.2/cgi/conf.d
Additional .ini files parsed /etc/php/7.2/cgi/conf.d/10-mysqlnd.ini, /etc/php/7.2/cgi/conf.d/10-opcache.ini, /etc/php/7.2/cgi/conf.d/10-pdo.ini, /etc/php/7.2/cgi/conf.d/15-xml.ini, /etc/php/7.2/cgi/conf.d/20-calendar.ini, /etc/php/7.2/cgi/conf.d/20-ctype.ini, /etc/php/7.2/cgi/conf.d/20-dom.ini, /etc/php/7.2/cgi/conf.d/20-exif.ini, /etc/php/7.2/cgi/conf.d/20-fileinfo.ini, /etc/php/7.2/cgi/conf.d/20-ftp.ini, /etc/php/7.2/cgi/conf.d/20-gd.ini, /etc/php/7.2/cgi/conf.d/20-gettext.ini, /etc/php/7.2/cgi/conf.d/20-iconv.ini, /etc/php/7.2/cgi/conf.d/20-imap.ini, /etc/php/7.2/cgi/conf.d/20-json.ini, /etc/php/7.2/cgi/conf.d/20-ldap.ini, /etc/php/7.2/cgi/conf.d/20-mbstring.ini, /etc/php/7.2/cgi/conf.d/20-mysqli.ini, /etc/php/7.2/cgi/conf.d/20-pdo_mysql.ini, /etc/php/7.2/cgi/conf.d/20-phar.ini, /etc/php/7.2/cgi/conf.d/20-posix.ini, /etc/php/7.2/cgi/conf.d/20-readline.ini, /etc/php/7.2/cgi/conf.d/20-shmop.ini, /etc/php/7.2/cgi/conf.d/20-simplexml.ini, /etc/php/7.2/cgi/conf.d/20-sockets.ini, /etc/php/7.2/cgi/conf.d/20-sysvmsg.ini, /etc/php/7.2/cgi/conf.d/20-sysvsem.ini, /etc/php/7.2/cgi/conf.d/20-sysvshm.ini, /etc/php/7.2/cgi/conf.d/20-tokenizer.ini, /etc/php/7.2/cgi/conf.d/20-wddx.ini, /etc/php/7.2/cgi/conf.d/20-xmlreader.ini, /etc/php/7.2/cgi/conf.d/20-xmlwriter.ini, /etc/php/7.2/cgi/conf.d/20-xsl.ini, /etc/php/7.2/cgi/conf.d/20-zip.ini
PHP API 20170718
PHP Extension 20170718
Zend Extension 320170718
Zend Extension Build API320170718,NTS
PHP Extension Build API20170718,NTS
Debug Build no
Thread Safety disabled
Zend Signal Handling enabled
Zend Memory Manager enabled
Zend Multibyte Support provided by mbstring
IPv6 Support enabled
DTrace Support available, disabled
Registered PHP Streams https, ftps, compress.zlib, php, file, glob, data, http, ftp, phar, zip
Registered Stream Socket Transports tcp, udp, unix, udg, ssl, tls, tlsv1.0, tlsv1.1, tlsv1.2
Registered Stream Filters zlib.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk, convert.iconv.*
Zend logo This program makes use of the Zend Scripting Language Engine:
Zend Engine v3.2.0, Copyright (c) 1998-2018 Zend Technologies
with Zend OPcache v7.2.10-0ubuntu0.18.04.1, Copyright (c) 1999-2018, by Zend Technologies
Configuration
calendar
Calendar support enabled
cgi-fcgi
Directive Local Value Master Value
cgi.check_shebang_line 1 1
cgi.discard_path 0 0
cgi.fix_pathinfo 1 1
cgi.force_redirect 1 1
cgi.nph 0 0
cgi.redirect_status_env no value no value
cgi.rfc2616_headers 0 0
fastcgi.logging 1 1
Core
allow_url_fopen On On
allow_url_include Off Off
arg_separator.input & &
arg_separator.output & &
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset UTF-8 UTF-8
default_mimetype text/html text/html
disable_classes no value no value
disable_functions pcntl_alarm,pcntl_fork,pcntl_waitpid,pcntl_wait,pcntl_wifexited,pcntl_wifstopped,pcntl_wifsignaled,pcntl_wifcontinued,pcntl_wexitstatus,pcntl_wtermsig,pcntl_wstopsig,pcntl_signal,pcntl_signal_get_handler,pcntl_signal_dispatch,pcntl_get_last_error,pcntl_strerror,pcntl_sigprocmask,pcntl_sigwaitinfo,pcntl_sigtimedwait,pcntl_exec,pcntl_getpriority,pcntl_setpriority,pcntl_async_signals, pcntl_alarm,pcntl_fork,pcntl_waitpid,pcntl_wait,pcntl_wifexited,pcntl_wifstopped,pcntl_wifsignaled,pcntl_wifcontinued,pcntl_wexitstatus,pcntl_wtermsig,pcntl_wstopsig,pcntl_signal,pcntl_signal_get_handler,pcntl_signal_dispatch,pcntl_get_last_error,pcntl_strerror,pcntl_sigprocmask,pcntl_sigwaitinfo,pcntl_sigtimedwait,pcntl_exec,pcntl_getpriority,pcntl_setpriority,pcntl_async_signals,
display_errors Off Off
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl Off Off
enable_post_data_reading On On
error_append_string no value no value
error_log no value no value
error_prepend_string no value no value
error_reporting 22527 22527
expose_php Off Off
extension_dir /usr/lib/php/20170718 /usr/lib/php/20170718
file_uploads On On
hard_timeout 2 2
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors On On
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path .:/usr/share/php .:/usr/share/php
input_encoding no value no value
internal_encoding no value no value
log_errors On On
log_errors_max_len 1024 1024
mail.add_x_header Off Off
mail.force_extra_parameters no value no value
mail.log no value no value
max_execution_time 30 30
max_file_uploads 20 20
max_input_nesting_level 64 64
max_input_time 60 60
max_input_vars 4000 4000
memory_limit 512M 512M
open_basedir no value no value
output_buffering 4096 4096
output_encoding no value no value
output_handler no value no value
post_max_size 8M 8M
precision 14 14
realpath_cache_size 4096K 4096K
realpath_cache_ttl 120 120
register_argc_argv Off Off
report_memleaks On On
report_zend_debug On On
request_order GP GP
sendmail_from no value no value
sendmail_path /usr/sbin/sendmail -t -i /usr/sbin/sendmail -t -i
serialize_precision -1 -1
short_open_tag Off Off
SMTP localhost localhost
smtp_port 25 25
sys_temp_dir no value no value
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 2M 2M
upload_tmp_dir no value no value
user_dir no value no value
user_ini.cache_ttl 300 300
user_ini.filename .user.ini .user.ini
variables_order GPCS GPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
zend.assertions -1 -1
zend.detect_unicode On On
zend.enable_gc On On
zend.multibyte Off Off
zend.script_encoding no value no value
zend.signal_check Off Off
ctype
ctype functions enabled
date
date/time support enabled
timelib version 2017.06
"Olson" Timezone Database Version 0.system
Timezone Database internal
Default timezone America/Chicago
date.default_latitude 31.7667 31.7667
date.default_longitude 35.2333 35.2333
date.sunrise_zenith 90.583333 90.583333
date.sunset_zenith 90.583333 90.583333
date.timezone no value no value
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.9.4
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
exif
EXIF Support enabled
EXIF Version 7.2.10-0ubuntu0.18.04.1
Supported EXIF Version 0220
Supported filetypes JPEG, TIFF
Multibyte decoding support using mbstring enabled
Extended EXIF tag formats Canon, Casio, Fujifilm, Nikon, Olympus, Samsung, Panasonic, DJI, Sony, Pentax, Minolta, Sigma, Foveon, Kyocera, Ricoh, AGFA, Epson
exif.decode_jis_intel JIS JIS
exif.decode_jis_motorola JIS JIS
exif.decode_unicode_intel UCS-2LE UCS-2LE
exif.decode_unicode_motorola UCS-2BE UCS-2BE
exif.encode_jis no value no value
exif.encode_unicode ISO-8859-15 ISO-8859-15
fileinfo
fileinfo support enabled
version 1.0.5
libmagic 531
filter
Input Validation and Filtering enabled
Revision $Id: 5a34caaa246b9df197f4b43af8ac66a07464fe4b $
filter.default unsafe_raw unsafe_raw
filter.default_flags no value no value
ftp
FTP support enabled
FTPS support enabled
gd
GD Support enabled
GD headers Version 2.2.5
GD library Version 2.2.5
FreeType Support enabled
FreeType Linkage with freetype
FreeType Version 2.8.1
GIF Read Support enabled
GIF Create Support enabled
JPEG Support enabled
libJPEG Version 8
PNG Support enabled
libPNG Version 1.6.34
WBMP Support enabled
XPM Support enabled
libXpm Version 30411
XBM Support enabled
WebP Support enabled
gd.jpeg_ignore_warning 1 1
gettext
GetText Support enabled
hash
hash support enabled
Hashing Engines md2 md4 md5 sha1 sha224 sha256 sha384 sha512/224 sha512/256 sha512 sha3-224 sha3-256 sha3-384 sha3-512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b fnv132 fnv1a32 fnv164 fnv1a64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
MHASH support Enabled
MHASH API Version Emulated Support
iconv
iconv support enabled
iconv implementation glibc
iconv library version 2.27
iconv.input_encoding no value no value
iconv.internal_encoding no value no value
iconv.output_encoding no value no value
imap
IMAP c-Client Version 2007f
SSL Support enabled
Kerberos Support enabled
json
json support enabled
json version 1.6.0
ldap
LDAP Support enabled
RCS Version $Id: 3839f871a91c293a52322c63329c68db23a0290a $
Total Links 0/unlimited
API Version 3001
Vendor Name OpenLDAP
Vendor Version 20445
SASL Support Enabled
ldap.max_links Unlimited Unlimited
libxml
libXML support active
libXML Compiled Version 2.9.4
libXML Loaded Version 20904
libXML streams enabled
mbstring
Multibyte Support enabled
Multibyte string engine libmbfl
HTTP input encoding translation disabled
libmbfl version 1.3.2
oniguruma version 6.3.0
mbstring extension makes use of "streamable kanji code filter and converter", which is distributed under the GNU Lesser General Public License version 2.1.
Multibyte (japanese) regex support enabled
Multibyte regex (oniguruma) backtrack check On
Multibyte regex (oniguruma) version 6.3.0
mbstring.detect_order no value no value
mbstring.encoding_translation Off Off
mbstring.func_overload 0 0
mbstring.http_input no value no value
mbstring.http_output no value no value
mbstring.http_output_conv_mimetypes ^(text/|application/xhtml\+xml) ^(text/|application/xhtml\+xml)
mbstring.internal_encoding no value no value
mbstring.language neutral neutral
mbstring.strict_detection Off Off
mbstring.substitute_character no value no value
mysqli
MysqlI Support enabled
Client API library version mysqlnd 5.0.12-dev - 20150407 - $Id: 38fea24f2847fa7519001be390c98ae0acafe387 $
Active Persistent Links 0
Inactive Persistent Links 0
Active Links 0
mysqli.allow_local_infile On On
mysqli.allow_persistent On On
mysqli.default_host no value no value
mysqli.default_port 3306 3306
mysqli.default_pw no value no value
mysqli.default_socket no value no value
mysqli.default_user no value no value
mysqli.max_links Unlimited Unlimited
mysqli.max_persistent Unlimited Unlimited
mysqli.reconnect Off Off
mysqli.rollback_on_cached_plink Off Off
mysqlnd
mysqlnd enabled
Version mysqlnd 5.0.12-dev - 20150407 - $Id: 38fea24f2847fa7519001be390c98ae0acafe387 $
Compression supported
core SSL supported
extended SSL supported
Command buffer size 4096
Read buffer size 32768
Read timeout 86400
Collecting statistics Yes
Collecting memory statistics No
Tracing n/a
Loaded plugins mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password,auth_plugin_caching_sha2_password,auth_plugin_sha256_password
API Extensions mysqli,pdo_mysql
mysqlnd statistics
bytes_sent 1346
bytes_received 4661
packets_sent 28
packets_received 128
protocol_overhead_in 512
protocol_overhead_out 112
bytes_received_ok_packet 0
bytes_received_eof_packet 0
bytes_received_rset_header_packet 36
bytes_received_rset_field_meta_packet 0
bytes_received_rset_row_packet 247
bytes_received_prepare_response_packet 1114
bytes_received_change_user_packet 3021
packets_sent_command 12
packets_received_ok 0
packets_received_eof 0
packets_received_rset_header 4
packets_received_rset_field_meta 0
packets_received_rset_row 9
packets_received_prepare_response 13
packets_received_change_user 97
result_set_queries 4
non_result_set_queries 1
no_index_used 4
bad_index_used 0
slow_queries 0
buffered_sets 4
unbuffered_sets 0
ps_buffered_sets 0
ps_unbuffered_sets 0
flushed_normal_sets 0
flushed_ps_sets 0
ps_prepared_never_executed 0
ps_prepared_once_executed 0
rows_fetched_from_server_normal 93
rows_fetched_from_server_ps 0
rows_buffered_from_client_normal 93
rows_buffered_from_client_ps 0
rows_fetched_from_client_normal_buffered 93
rows_fetched_from_client_normal_unbuffered 0
rows_fetched_from_client_ps_buffered 0
rows_fetched_from_client_ps_unbuffered 0
rows_fetched_from_client_ps_cursor 0
rows_affected_normal 0
rows_affected_ps 0
rows_skipped_normal 93
rows_skipped_ps 0
copy_on_write_saved 0
copy_on_write_performed 0
command_buffer_too_small 0
connect_success 2
connect_failure 0
connection_reused 0
reconnect 0
pconnect_success 1
active_connections 18446744073709551614
active_persistent_connections 18446744073709551615
explicit_close 2
implicit_close 0
disconnect_close 0
in_middle_of_command_close 0
explicit_free_result 4
implicit_free_result 0
explicit_stmt_close 0
implicit_stmt_close 0
mem_emalloc_count 0
mem_emalloc_amount 0
mem_ecalloc_count 0
mem_ecalloc_amount 0
mem_erealloc_count 0
mem_erealloc_amount 0
mem_efree_count 0
mem_efree_amount 0
mem_malloc_count 0
mem_malloc_amount 0
mem_calloc_count 0
mem_calloc_amount 0
mem_realloc_count 0
mem_realloc_amount 0
mem_free_count 0
mem_free_amount 0
mem_estrndup_count 0
mem_strndup_count 0
mem_estrdup_count 0
mem_strdup_count 0
mem_edupl_count 0
mem_dupl_count 0
proto_text_fetched_null 0
proto_text_fetched_bit 0
proto_text_fetched_tinyint 7
proto_text_fetched_short 0
proto_text_fetched_int24 0
proto_text_fetched_int 47
proto_text_fetched_bigint 0
proto_text_fetched_decimal 0
proto_text_fetched_float 0
proto_text_fetched_double 0
proto_text_fetched_date 0
proto_text_fetched_year 0
proto_text_fetched_time 0
proto_text_fetched_datetime 0
proto_text_fetched_timestamp 0
proto_text_fetched_string 169
proto_text_fetched_blob 0
proto_text_fetched_enum 10
proto_text_fetched_set 0
proto_text_fetched_geometry 0
proto_text_fetched_other 0
proto_binary_fetched_null 0
proto_binary_fetched_bit 0
proto_binary_fetched_tinyint 0
proto_binary_fetched_short 0
proto_binary_fetched_int24 0
proto_binary_fetched_int 0
proto_binary_fetched_bigint 0
proto_binary_fetched_decimal 0
proto_binary_fetched_float 0
proto_binary_fetched_double 0
proto_binary_fetched_date 0
proto_binary_fetched_year 0
proto_binary_fetched_time 0
proto_binary_fetched_datetime 0
proto_binary_fetched_timestamp 0
proto_binary_fetched_string 0
proto_binary_fetched_json 0
proto_binary_fetched_blob 0
proto_binary_fetched_enum 0
proto_binary_fetched_set 0
proto_binary_fetched_geometry 0
proto_binary_fetched_other 0
init_command_executed_count 0
init_command_failed_count 0
com_quit 2
com_init_db 1
com_query 9
com_field_list 0
com_create_db 0
com_drop_db 0
com_refresh 0
com_shutdown 0
com_statistics 0
com_process_info 0
com_connect 0
com_process_kill 0
com_debug 0
com_ping 0
com_time 0
com_delayed_insert 0
com_change_user 0
com_binlog_dump 0
com_table_dump 0
com_connect_out 0
com_register_slave 0
com_stmt_prepare 0
com_stmt_execute 0
com_stmt_send_long_data 0
com_stmt_close 0
com_stmt_reset 0
com_stmt_set_option 0
com_stmt_fetch 0
com_deamon 0
bytes_received_real_data_normal 2400
bytes_received_real_data_ps 0
openssl
OpenSSL support enabled
OpenSSL Library Version OpenSSL 1.1.0g 2 Nov 2017
OpenSSL Header Version OpenSSL 1.1.0g 2 Nov 2017
Openssl default config /usr/lib/ssl/openssl.cnf
openssl.cafile no value no value
openssl.capath no value no value
pcntl
pcntl support enabled
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 8.39 2016-06-14
PCRE JIT Support enabled
pcre.backtrack_limit 1000000 1000000
pcre.jit 1 1
pcre.recursion_limit 100000 100000
PDO
PDO support enabled
PDO drivers mysql
pdo_mysql
PDO Driver for MySQL enabled
Client API version mysqlnd 5.0.12-dev - 20150407 - $Id: 38fea24f2847fa7519001be390c98ae0acafe387 $
pdo_mysql.default_socket /var/run/mysqld/mysqld.sock /var/run/mysqld/mysqld.sock
Phar
Phar: PHP Archive support enabled
Phar EXT version 2.0.2
Phar API version 1.1.1
SVN revision $Id: 961be29fd3e2f5fe1458eb9c98adde5d37660d26 $
Phar-based phar archives enabled
Tar-based phar archives enabled
ZIP-based phar archives enabled
gzip compression enabled
bzip2 compression disabled (install pecl/bz2)
Native OpenSSL support enabled
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list no value no value
phar.readonly On On
phar.require_hash On On
posix
Revision $Id: c3261323fa6808fa0c785f00c0741892d57ef0c4 $
readline
Readline Support enabled
Readline library EditLine wrapper
cli.pager no value no value
cli.prompt \b \> \b \>
Reflection
Reflection enabled
Version $Id: a0d4ebb4a00a610b72686facdf62693a7855fc2b $
session
Session Support enabled
Registered save handlers files user
Registered serializer handlers php_serialize php php_binary wddx
session.auto_start Off Off
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_httponly no value no value
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure 0 0
session.gc_divisor 1000 1000
session.gc_maxlifetime 1440 1440
session.gc_probability 0 0
session.lazy_write On On
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path /var/lib/php/sessions /var/lib/php/sessions
session.serialize_handler php php
session.sid_bits_per_character 5 5
session.sid_length 26 26
session.upload_progress.cleanup On On
session.upload_progress.enabled On On
session.upload_progress.freq 1% 1%
session.upload_progress.min_freq 1 1
session.upload_progress.name PHP_SESSION_UPLOAD_PROGRESS PHP_SESSION_UPLOAD_PROGRESS
session.upload_progress.prefix upload_progress_ upload_progress_
session.use_cookies 1 1
session.use_only_cookies 1 1
session.use_strict_mode 0 0
session.use_trans_sid 0 0
shmop
shmop support enabled
SimpleXML
Simplexml support enabled
Revision $Id: 341daed0ee94ea8f728bfd0ba4626e6ed365c0d1 $
Schema support enabled
sockets
Sockets Support enabled
sodium
sodium support enabled
libsodium headers version 1.0.16
libsodium library version 1.0.16
SPL
SPL support enabled
Interfaces OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
standard
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -i
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.exception 0 0
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
session.trans_sid_hosts no value no value
session.trans_sid_tags a=href,area=href,frame=src,form= a=href,area=href,frame=src,form=
url_rewriter.hosts no value no value
url_rewriter.tags form= form=
user_agent no value no value
sysvmsg
sysvmsg support enabled
Revision $Id: 73c7c7668de72405a739f837dc62fd6ce8e5eba6 $
sysvsem
sysvshm
tokenizer
Tokenizer Support enabled
wddx
WDDX Support enabled
WDDX Session Serializer enabled
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.9.4
xmlreader
XMLReader enabled
xmlwriter
XMLWriter enabled
xsl
XSL enabled
libxslt Version 1.1.29
libxslt compiled against libxml Version 2.9.4
EXSLT enabled
libexslt Version 1.1.29
Zend OPcache
Opcode Caching Up and Running
Optimization Enabled
SHM Cache Enabled
File Cache Disabled
Startup OK
Shared memory model mmap
Cache hits 673
Cache misses 140
Used memory 25974528
Free memory 108243200
Wasted memory 0
Interned Strings Used memory 1440576
Interned Strings Free memory 6948032
Cached scripts 137
Cached keys 194
Max keys 16229
OOM restarts 0
Hash keys restarts 0
Manual restarts 0
opcache.blacklist_filename no value no value
opcache.consistency_checks 0 0
opcache.dups_fix Off Off
opcache.enable On On
opcache.enable_cli Off Off
opcache.enable_file_override Off Off
opcache.error_log no value no value
opcache.file_cache no value no value
opcache.file_cache_consistency_checks 1 1
opcache.file_cache_only 0 0
opcache.file_update_protection 2 2
opcache.force_restart_timeout 180 180
opcache.huge_code_pages Off Off
opcache.inherited_hack On On
opcache.interned_strings_buffer 8 8
opcache.lockfile_path /tmp /tmp
opcache.log_verbosity_level 1 1
opcache.max_accelerated_files 10000 10000
opcache.max_file_size 0 0
opcache.max_wasted_percentage 5 5
opcache.memory_consumption 128 128
opcache.opt_debug_level 0 0
opcache.optimization_level 0x7FFFBFFF 0x7FFFBFFF
opcache.preferred_memory_model no value no value
opcache.protect_memory 0 0
opcache.restrict_api no value no value
opcache.revalidate_freq 2 2
opcache.revalidate_path Off Off
opcache.save_comments 1 1
opcache.use_cwd On On
opcache.validate_permission Off Off
opcache.validate_root Off Off
opcache.validate_timestamps On On
zip
Zip enabled
Zip version 1.15.3
Libzip version 1.1.2
zlib
ZLib Support enabled
Stream Wrapper compress.zlib://
Stream Filter zlib.inflate, zlib.deflate
Compiled Version 1.2.11
Linked Version 1.2.11
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Additional Modules
Module Name
Environment
Variable Value
PATH /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
PHP_FCGI_CHILDREN 4
PHP_FCGI_MAX_REQUESTS 10000
PHP Variables
Variable Value
$_COOKIE 1;2;5
$_COOKIE ku84bff0bese2at8lhuat9euhc
$_SERVER /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
$_SERVER 4
$_SERVER 10000
$_SERVER MANTIS_PROJECT_COOKIE=1%3B2%3B5; PHPSESSID=ku84bff0bese2at8lhuat9euhc
$_SERVER en-US,en;q=0.9
$_SERVER gzip, deflate
$_SERVER text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
$_SERVER Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/69.0.3497.100 Safari/537.36
$_SERVER 1
$_SERVER keep-alive
$_SERVER databox
$_SERVER 40878
$_SERVER 10.0.69.119
$_SERVER databox
$_SERVER 10.0.69.101
$_SERVER 80
$_SERVER CGI/1.1
$_SERVER lighttpd/1.4.45
$_SERVER HTTP/1.1
$_SERVER GET
$_SERVER /var/www/html
$_SERVER /var/www/html/info.php
$_SERVER /info.php
$_SERVER 200
$_SERVER /info.php
$_SERVER no value
$_SERVER 0
$_SERVER RESPONDER
$_SERVER /info.php
$_SERVER 1537898164.714
$_SERVER 1537898164
PHP Credits
PHP Group
Thies C. Arntzen, Stig Bakken, Shane Caraveo, Andi Gutmans, Rasmus Lerdorf, Sam Ruby, Sascha Schumann, Zeev Suraski, Jim Winstead, Andrei Zmievski
Language Design & Concept
Andi Gutmans, Rasmus Lerdorf, Zeev Suraski, Marcus Boerger
PHP Authors
Contribution Authors
Zend Scripting Language Engine Andi Gutmans, Zeev Suraski, Stanislav Malyshev, Marcus Boerger, Dmitry Stogov, Xinchen Hui, Nikita Popov
Extension Module API Andi Gutmans, Zeev Suraski, Andrei Zmievski
UNIX Build and Modularization Stig Bakken, Sascha Schumann, Jani Taskinen
Windows Support Shane Caraveo, Zeev Suraski, Wez Furlong, Pierre-Alain Joye, Anatol Belski, Kalle Sommer Nielsen
Server API (SAPI) Abstraction Layer Andi Gutmans, Shane Caraveo, Zeev Suraski
Streams Abstraction Layer Wez Furlong, Sara Golemon
PHP Data Objects Layer Wez Furlong, Marcus Boerger, Sterling Hughes, George Schlossnagle, Ilia Alshanetsky
Output Handler Zeev Suraski, Thies C. Arntzen, Marcus Boerger, Michael Wallner
Consistent 64 bit support Anthony Ferrara, Anatol Belski
SAPI Modules
Apache 2.0 Handler Ian Holsman, Justin Erenkrantz (based on Apache 2.0 Filter code)
CGI / FastCGI Rasmus Lerdorf, Stig Bakken, Shane Caraveo, Dmitry Stogov
CLI Edin Kadribasic, Marcus Boerger, Johannes Schlueter, Moriyoshi Koizumi, Xinchen Hui
Embed Edin Kadribasic
FastCGI Process Manager Andrei Nigmatulin, dreamcat4, Antony Dovgal, Jerome Loyet
litespeed George Wang
phpdbg Felipe Pena, Joe Watkins, Bob Weinand
Module Authors
Module Authors
BC Math Andi Gutmans
Bzip2 Sterling Hughes
Calendar Shane Caraveo, Colin Viebrock, Hartmut Holzgraefe, Wez Furlong
COM and .Net Wez Furlong
ctype Hartmut Holzgraefe
cURL Sterling Hughes
Date/Time Support Derick Rethans
DB-LIB (MS SQL, Sybase) Wez Furlong, Frank M. Kromann, Adam Baratz
DBA Sascha Schumann, Marcus Boerger
DOM Christian Stocker, Rob Richards, Marcus Boerger
enchant Pierre-Alain Joye, Ilia Alshanetsky
EXIF Rasmus Lerdorf, Marcus Boerger
fileinfo Ilia Alshanetsky, Pierre Alain Joye, Scott MacVicar, Derick Rethans, Anatol Belski
Firebird driver for PDO Ard Biesheuvel
FTP Stefan Esser, Andrew Skalski
GD imaging Rasmus Lerdorf, Stig Bakken, Jim Winstead, Jouni Ahto, Ilia Alshanetsky, Pierre-Alain Joye, Marcus Boerger
GetText Alex Plotnick
GNU GMP support Stanislav Malyshev
Iconv Rui Hirokawa, Stig Bakken, Moriyoshi Koizumi
IMAP Rex Logan, Mark Musone, Brian Wang, Kaj-Michael Lang, Antoni Pamies Olive, Rasmus Lerdorf, Andrew Skalski, Chuck Hagenbuch, Daniel R Kalowsky
Input Filter Rasmus Lerdorf, Derick Rethans, Pierre-Alain Joye, Ilia Alshanetsky
InterBase Jouni Ahto, Andrew Avdeev, Ard Biesheuvel
Internationalization Ed Batutis, Vladimir Iordanov, Dmitry Lakhtyuk, Stanislav Malyshev, Vadim Savchuk, Kirti Velankar
JSON Jakub Zelenka, Omar Kilani, Scott MacVicar
LDAP Amitay Isaacs, Eric Warnke, Rasmus Lerdorf, Gerrit Thomson, Stig Venaas
LIBXML Christian Stocker, Rob Richards, Marcus Boerger, Wez Furlong, Shane Caraveo
Multibyte String Functions Tsukada Takuya, Rui Hirokawa
MySQL driver for PDO George Schlossnagle, Wez Furlong, Ilia Alshanetsky, Johannes Schlueter
MySQLi Zak Greant, Georg Richter, Andrey Hristov, Ulf Wendel
MySQLnd Andrey Hristov, Ulf Wendel, Georg Richter, Johannes Schlüter
OCI8 Stig Bakken, Thies C. Arntzen, Andy Sautins, David Benson, Maxim Maletsky, Harald Radi, Antony Dovgal, Andi Gutmans, Wez Furlong, Christopher Jones, Oracle Corporation
ODBC driver for PDO Wez Furlong
ODBC Stig Bakken, Andreas Karajannis, Frank M. Kromann, Daniel R. Kalowsky
Opcache Andi Gutmans, Zeev Suraski, Stanislav Malyshev, Dmitry Stogov, Xinchen Hui
OpenSSL Stig Venaas, Wez Furlong, Sascha Kettler, Scott MacVicar
Oracle (OCI) driver for PDO Wez Furlong
pcntl Jason Greene, Arnaud Le Blanc
Perl Compatible Regexps Andrei Zmievski
PHP Archive Gregory Beaver, Marcus Boerger
PHP Data Objects Wez Furlong, Marcus Boerger, Sterling Hughes, George Schlossnagle, Ilia Alshanetsky
PHP hash Sara Golemon, Rasmus Lerdorf, Stefan Esser, Michael Wallner, Scott MacVicar
Posix Kristian Koehntopp
PostgreSQL driver for PDO Edin Kadribasic, Ilia Alshanetsky
PostgreSQL Jouni Ahto, Zeev Suraski, Yasuo Ohgaki, Chris Kings-Lynne
Pspell Vlad Krupin
Readline Thies C. Arntzen
Recode Kristian Koehntopp
Reflection Marcus Boerger, Timm Friebe, George Schlossnagle, Andrei Zmievski, Johannes Schlueter
Sessions Sascha Schumann, Andrei Zmievski
Shared Memory Operations Slava Poliakov, Ilia Alshanetsky
SimpleXML Sterling Hughes, Marcus Boerger, Rob Richards
SNMP Rasmus Lerdorf, Harrie Hazewinkel, Mike Jackson, Steven Lawrance, Johann Hanne, Boris Lytochkin
SOAP Brad Lafountain, Shane Caraveo, Dmitry Stogov
Sockets Chris Vandomelen, Sterling Hughes, Daniel Beulshausen, Jason Greene
Sodium Frank Denis
SPL Marcus Boerger, Etienne Kneuss
SQLite 3.x driver for PDO Wez Furlong
SQLite3 Scott MacVicar, Ilia Alshanetsky, Brad Dewar
System V Message based IPC Wez Furlong
System V Semaphores Tom May
System V Shared Memory Christian Cartus
tidy John Coggeshall, Ilia Alshanetsky
tokenizer Andrei Zmievski, Johannes Schlueter
WDDX Andrei Zmievski
XML Stig Bakken, Thies C. Arntzen, Sterling Hughes
XMLReader Rob Richards
xmlrpc Dan Libby
XMLWriter Rob Richards, Pierre-Alain Joye
XSL Christian Stocker, Rob Richards
Zip Pierre-Alain Joye, Remi Collet
Zlib Rasmus Lerdorf, Stefan Roehrich, Zeev Suraski, Jade Nicoletti, Michael Wallner
PHP Documentation
Authors Mehdi Achour, Friedhelm Betz, Antony Dovgal, Nuno Lopes, Hannes Magnusson, Philip Olson, Georg Richter, Damien Seguy, Jakub Vrana, Adam Harvey
Editor Peter Cowburn
User Note Maintainers Daniel P. Brown, Thiago Henrique Pojda
Other Contributors Previously active authors, editors and other contributors are listed in the manual.
PHP Quality Assurance Team
Ilia Alshanetsky, Joerg Behrens, Antony Dovgal, Stefan Esser, Moriyoshi Koizumi, Magnus Maatta, Sebastian Nohn, Derick Rethans, Melvyn Sopacua, Jani Taskinen, Pierre-Alain Joye, Dmitry Stogov, Felipe Pena, David Soria Parra, Stanislav Malyshev, Julien Pauli, Stephen Zarkos, Anatol Belski, Remi Collet, Ferenc Kovacs
Websites and Infrastructure team
PHP Websites Team Rasmus Lerdorf, Hannes Magnusson, Philip Olson, Lukas Kahwe Smith, Pierre-Alain Joye, Kalle Sommer Nielsen, Peter Cowburn, Adam Harvey, Ferenc Kovacs, Levi Morrison
Event Maintainers Damien Seguy, Daniel P. Brown
Network Infrastructure Daniel P. Brown
Windows Infrastructure Alex Schoenmaker
PHP License
This program is free software; you can redistribute it and/or modify it under the terms of the PHP License as published by the PHP Group and included in the distribution in the file: LICENSE
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any questions about PHP licensing, please contact This email address is being protected from spambots. You need JavaScript enabled to view it..
26 Sep 2018 20:01 #2 by babynus
First, it seems you already ran install that did not complete.
This is why you get message :
To avoid this, delete file projeqtor/files/cron/MIGRATION
Also you should face an install issue that is fixed on V7.2.3.
Try brand new install with this version.
The following user(s) said Thank You: jmetcalf
27 Sep 2018 15:49 #3 by jmetcalf
Babynus,
Thank you for the quick reply. Dropping the database out of MySQL and installing v7.2.3 seems to have resolved the issue.
A couple of things to note for other noob users:
1) verify that the "web user", in my case "www-data" has read & write access to the entire directory structure
2) depending on your server it may take a really long time for ProjeQqOr to build the database and will appear that it is hung while you are attempting to login ad admin for the first time. I monitored the progress of the tables being built by watching the log files (tail -f [log file]) and monitored the MySQL database using the HeidiSQL application.
