ProjeQtOr free project management software - Problème caractère / Character problem - ProjeQtOr
20 Sep 2018 09:20 #1 by protion
Bonjour
J'ai depuis quelque jour un problème de caractères, j'ai plus aucun accent ou apostrophe, alors que je n'est fait aucune manipulation.
Merci de votre aide par avance
Cordialement
I have a character problem since a few days, I have no more accent or apostrophe, whereas I have no manipulation.
Thank you in advance for your help
cordially
21 Sep 2018 09:02 #2 by babynus
If accents were present and are not any more, sure there was some manipilation done (maybe not yours, but there is)
It could be :
- export / import with bad encoding
- change of PHP server parameters
- change of MySql server parameter
- change of some projector parameter (for instance the value for $enforceUTF8)
Find what was done, you'll get how to fix.
