ProjeQtOr free project management software - [SOLVED] Stuck with sendmail and projeqtor - Page 3 - ProjeQtOr
13 Mar 2019 16:01 #13 by 4ce
hi there - thank you for your response.
the reply to address is exactly like the sender email. and inbox was written in any given ways, but still "Mailbox is empty". i wrote a short test.php which access the imap via the connection string and lists the inbox. and it works fine. in fact that "mailbox is empty" appears if i define any foldername (xxx or whatever) seems to me that the cron.php builds an errornous connection string. connection works, the connection string works manually written in a test.php. no error message appears.
the original mail was left, even with blank spaces and in several tests in rich text/html/plain text. nothing will work.
it driving me nuts
13 Mar 2019 16:10 #14 by babynus
Could you please explain this part :
13 Mar 2019 16:23 #15 by 4ce
in the connection string i can typ any name as folder and everytime "mailbox is empty" appears. for example
- }Inbox -> folder exists but "mailbox is empty" appears
- }ABCDEF -> folder did not exist but the message "maibox is empty" appears
so for me it seems that everytime the foldername is not correct and the folder did not exist the message "mailbox is empty" is in the log.
if i left the connection string without folder name - an error appears that the foldername is missing.
in my test php file, "Inbox" as foldername work fine. so i guessed that the cron eventually deforms the parameters out of the global parameters into an errornous string.
can you follow my explanations?
13 Mar 2019 17:30 - 13 Mar 2019 17:32 #16 by jmmbb
same issue for me.
Using Telnet, i'm able to connect to mailbox and listing folders...
But nothing's working via Projeqtor
2019-03-13 17:23:47.663 DEBUG Mailbox is empty
2019-03-13 17:28:48.338 DEBUG Mailbox is empty
Last edit: 13 Mar 2019 17:32 by jmmbb.
13 Mar 2019 17:42 #17 by babynus
did you configure MAILBOX name in upper case in the parameters ?
14 Mar 2019 08:29 #18 by 4ce
hi babynus,
thank you for your patience.
and yes, of course i did. i attached our configurations: screenshot 1 and 2
sending mail works fine. no matter what i tried in imap parameters i still get the log:
2019-03-14 08:10:05.694 ===== TRACE ===== Cron started at 14/03/2019 08:10:05
2019-03-14 08:10:15.749
DEBUG
Mailbox is empty
the connect seems to work from this client. i wrote a test php (screen3 is the php-file) and the results of this php are in screen4.
as you also see in screen 4 is that i tried several formats of mails (plain, html, rich)
any further clues?
@jmmbb
i see that the most mails are tagged as "seen". but projeqtor only imports "unseen undeleted' mails. maybe you should try to have a look on this, if this is not already tested.
