ProjeQtOr free project management software - Trying to Change Validated End Date and Receive Technical Issue occurred - Page 2 - ProjeQtOr
11 Sep 2018 08:58 #7 by babynus
did you clean your browser cache ?
11 Sep 2018 12:37 #8 by iconic
I cannot explain but I fixed this issue. I found that there a few notes on the activity that had no user name attach to it and in the database these notes were showing a value of 0 in the idle column.
I correct the user id manually and changed the values to 1 and the problem was fixed.
I am not sure what the idle column does but this seemed to fix the problem.
11 Sep 2018 14:55 #9 by babynus
Value of idle to 1 leads to non display of note.
It should be interesting to understand how you got notes without user.
Maybe if you could look at history of element, you could check when the note was saved and what may have occured.
We would be gratefull to have a clue to identify source of issue.
11 Sep 2018 16:26 #10 by iconic
Will do, however can you explain when you say
Do you mean in the Database? If YES, what is the name of the table/column
If you mean somewhere else, please advise of its exact location.
13 Sep 2018 09:19 #11 by babynus
No, I mean acces item history through the application.
In user parameters, check parameter "show history"
If you select YES, you'll always see history at bottom of description.
If you select "ON REQUEST", you'll have a button (hourglass icon) to access to history in pop-up mode (my advise)
14 Sep 2018 01:51 #12 by iconic
I did what you said and the history of the activity shows the date and times to be correct and does not show any errors. It seems correct the History Log of the activity. The only thing is that I did find that the notes where I had to change the idle value, they do not have a username in the username column. They are blank in this cell for those notes.
Could this have been the problem?
