ProjeQtOr free project management software - classification problem - ProjeQtOr
30 Aug 2018 17:43 #1 by ZMN
classification problem was created by ZMN
Hi
I want to rank alphabetically the name of the manager in the tab "Projects" but it dosn't work correctly. I don't know how to do to order it in the right way.
Thank you
31 Aug 2018 19:36 #2 by babynus
Replied by babynus on topic classification problem
I think it is already sorted on alphabetic order.
03 Sep 2018 17:11 - 03 Sep 2018 17:12 #3 by ZMN
Replied by ZMN on topic classification problem
No i'm talking about this
Last edit: 03 Sep 2018 17:12 by ZMN.
03 Sep 2018 18:05 #4 by babynus
Just click on column header to get correct sorting.
Or apply corresponding filter, that you can store and set as default.
17 Sep 2018 14:53 - 17 Sep 2018 14:54 #5 by ZMN
I click on column header but It dosen't works for manager, I don't know why !
I have the version 6.5.7
Last edit: 17 Sep 2018 14:54 by ZMN.
17 Sep 2018 15:09 #6 by babynus
It may be an old issue.
Try it on demo.
If it works as expected, consider migrating to V7.1.5
