ProjeQtOr free project management software - Organization structure and choosing the right profiles - ProjeQtOr
24 Aug 2018 14:08 #1 by VERP
I've setup a simple test organization, one department with 3 units.
Each of them is assigned a manager.
The department manager I gave the supervisor profile and the unit managers got the project leader profile.
After entering real work, the supervisor cannot see the timesheet entries of other resources.
What are the correct profiles to assign in order that the department manager can see timesheets of all the underlying resources?
Thanks in advance
24 Aug 2018 14:40 #2 by alainforma
hi,
You have to go to access rights then specifics access, select for the profile supervisor and project manager what they have the right to see on the lines named "access for time timesheet for resources" and "validate real work" choosing beetween options.
best regards.
28 Aug 2018 09:07 #3 by babynus
First, access rights are defined at Project Level.
You can use Organization level to restrict visibility to resource.
This is done at specific access rights.
