ProjeQtOr free project management software - [SOLVED] Extra fields on project-level - ProjeQtOr
24 Aug 2018 08:04 #1 by VERP
We would like to add the "in scope" and "out of scope" elements during project definition.
Is it possible to create those "new" fields with the Screen Customization plug-in?
If so, do we need it once or per user?
Thanks in advance
24 Aug 2018 08:54 #2 by babynus
Yes, screen customization plugin is designed for this.
You need only 1 licence (for the server whatever the number of user).
