ProjeQtOr free project management software - [SOLVED] Approver for non Document class - ProjeQtOr
16 Aug 2018 15:42 #1 by Envergus
I am trying to use Approver for non document classes. In objectDetail.php $versApp is defined if object is a Document however it is used in all cases which produces an error if the object is not a Document,
may it be fixed in new versions?
Best Regards
16 Aug 2018 15:51 #2 by babynus
It's because as of today approvers is only for Documents.
Look at the code, it's clear it's document oriented.
Just fixing the issue on $versApp won't solve global design constraint : you'll sure get issues elsewhere, when displaying approvers, ...
So we won't spend time to "fix" code that is working and only needed for your own need.
16 Aug 2018 15:53 #3 by Envergus
Ok Thank you for your time
