ProjeQtOr free project management software - When i launch first configuration - Page 2 - ProjeQtOr
08 Aug 2018 21:44 #7 by babynus
Have a look at message : cannot write to such a file : check access rights
I guess all your files and directories are readonly (sometimes the result of unzipping)
Change access rights (at least to all content of folder projeqtor/files including sub-directories)
09 Aug 2018 18:39 #8 by rvasighi
i did change the rights of file as you told me, but i have the same massage.!
incorrect value for 'Log file name', cannot write to such a file : check access rights
it talk about log file name!
in configuration windows:
../files/logs/projeqtor_${date}.log.
i verified the Logs folder , we have not a file name like this. is system must create a file log (projeqtor_${date}.log) in the first configuration? or this file must before exist?
09 Aug 2018 18:54 #9 by babynus
Yes, the system will create the log file (one per day).
But it needs write access rights to do this.
Don't forget that it is the PHP user (internal user who launched PHP) that needs to be able to write, and it may be different from your current user.
So best it to give write rights to every user to be sure.
09 Aug 2018 20:14 #10 by rvasighi
Thanks for your support.
its solved!!!!
i got it
