ProjeQtOr free project management software - [SOLVED] Recurring task not visible on diary - Page 2 - ProjeQtOr
02 Aug 2018 11:20 #7 by alay
The use of milestones with fixed dates (predecessor/successor or not) does not work.
By adding the validated dates (start and end) to the project, the task is now visible.
Thanks you
02 Aug 2018 11:56 #8 by alainforma
HI,
Please explain your issue with attachment if possible.
02 Aug 2018 13:22 #9 by alay
You will find screenshots as an attachment.
I entered the dates of validity(beginand end ): the task is now visible in the diary.
02 Aug 2018 14:01 #10 by alainforma
yes it is normal ; planified dates encompass the month august.
What is your issue with milestone ?
02 Aug 2018 14:11 #11 by alay
I created 2 milestones with fixed dates:
- milestone number 1 (beginning): 01/01/2018
- milestone number 2 (end): 31/12/2018
To the task, I added:
- predecessor milestone number 1
- sucessor milestone number 2
But the task still did not appear in the diary
02 Aug 2018 14:18 #12 by babynus
To determine end of recurring task, you must not add successor with end-start relationship.
This would mean : I calculate the task, then I want to have the milstone after the end date.
To get what you wnat you need to define last milestone as Predecessor with end-to-end relationship.
This means the end date of the milestone determines the end date of the task (it's what you want)
