ProjeQtOr free project management software - [SOLVED] Plug-in Screen Customization - impacts for updated forms - ProjeQtOr
01 Aug 2018 10:56 #1 by LEADER
I want to know if I modify form with plug-in Screen customization, i must update form when new version of product will be available.
I want to add some filed on Project form (to add (for example): ITIL Process (Incident, Change, Problem, .....) must be implemented and followed.
Thank you for your answer
01 Aug 2018 11:40 #2 by babynus
Of course not :woohoo:
This is all the interest of the plugin B)
Easy.
You can add new list field, with own content.
The following user(s) said Thank You: LEADER
