ProjeQtOr free project management software - loosing component definition - Page 2 - ProjeQtOr
22 Aug 2018 15:04 #7 by babynus
it seems that I don't have exactly the same interface on component version ...
It may depend on global parameters for "configuration" parameters.
Could you post screenshot of your parameters ?
However it seems that all "close" relation works 'fine' on the demo site , much more better than on my own intranet site
It can be due to parameters or unproper browser cache. Try and clean browser cache.
23 Aug 2018 08:45 #8 by ashofphoenix
I've tried several small things :
I manage to keep visible the sub components used in older "closed" version using the Option "display product version on delivery" ... hum... don't really understand the link between that, but putting ON this option makes the deal !!!
Thanks for your time
