ProjeQtOr free project management software - ${dbName} and ${adminMail} not filled with values - ProjeQtOr
24 Jul 2018 12:57 #1 by ancm
When I generate the introductory message the values for ${dbName} and ${adminMail} are not filled with he actual values. This was after update from 6.0.4 to 7.1.3. I had to rewrite the entire config section of parameters after upgrading because it was wiped. Any clues?
See message example below:
You are welcome to ${dbName} at https://x.x.x/projeqtor
Your login is a@b.c
Your password is initialized to abcdefgh
You will have to change it on first connection.
In case of an issue contact your administrator at ${adminMail}.
Kind regards,
Project Management
24 Jul 2018 16:55 #2 by babynus
I guess the CRON system just required a restart.
