ProjeQtOr free project management software - [SOLVED] Impossible to Copy Project V7.0.9 - ProjeQtOr
11 Jul 2018 17:01 - 12 Jul 2018 09:52 #1 by ashofphoenix
I Created a projet As Project Leader.
I'm Trying to copy it to a new one using the "Copy Current Project" button with 'default setting' Changing Project Name and Code
I've got the Error "Invalid controls, you don't have rights to create this item" ... hum.... well I can properly create a project but I can't copy a project... ??
Thanks for your help again
Last edit: 12 Jul 2018 09:52 by ashofphoenix.
12 Jul 2018 09:42 #2 by alainforma
HI,
This anomaly has been corrected - ticket 3422-.
Version 7.1.2 takes into account this fix.
12 Jul 2018 09:52 #3 by ashofphoenix
ok for this !!!
