ProjeQtOr free project management software - ldap issue - ProjeQtOr
ldap issue
09 Jul 2018 21:38 #1 by ffq
ldap issue was created by ffq
Im trying to config ldap projeqtor and i always got this error. Could someone help me please. here is attached my parameters files. thanks for nay help
File Attachment:
File Name: parameters.txt
File Size:2 KB
2018-07-09 14:39:09.271 ***** ERROR ***** [V7.0.9] ERROR *****
2018-07-09 14:39:09.272 ***** ERROR ***** [V7.0.9] on file '/home/projeqtor/public_html/model/UserMain.php' at line (1141)
2018-07-09 14:39:09.272 ***** ERROR ***** [V7.0.9] cause = ldap_bind(): Unable to bind to server: Can't contact LDAP server
10 Jul 2018 22:11 #2 by babynus
Replied by babynus on topic ldap issue
Message is "Can't contact LDAP server'
So either ldap host is not correct
or port is not correct
or port in now open on server
or network does not allow flow
Ckeck LDAP logs to have infos.
11 Jul 2018 14:49 #3 by ffq
Replied by ffq on topic ldap issue
hi
this is the log that is generated the host and the port is ok because i can access it using ldapadmin. I know m ldap only support ssl or tls connection. The logs says line 1141 in the attached file but i dont have a big idea about whats wrong in the file. Could you help me figure this out please^
12 Jul 2018 09:41 #4 by babynus
ProjeQtOr supports Ldaps but not Ldap over SSL.
This is subject of ticket #3103
The following user(s) said Thank You: ffq
